This is Panasonic TV set Model CT-35G21U. It was identified as blown fuse symptom immediately after turn on the TV. Found defecting PS IC STK370-020 because of Pin# 12 and Pin# 9 were shorted. After IC was replaced TV works ok. However, there are differences between the voltage on Pin# 4 (negative -.30v against positive .25v as noted on the schematic) and on Pin# 12 (152v against 135.9v as noted). All PS primary and secondary voltages are close to noted. The only, PS transformer T801 looks as to hot. May any on explain this condition?
TV problem
Thu, 10/20/2005 - 01:41
TV problem
