Help, My sony TV just went dead and I don't know what happend. When I try to turn the tv on it doesn't do anything. The little light in the front just keeps blinking. It is supposed to fo that and then cut on. I don't know if the power supply went bad or something else. If someone can help me out with this I would appreciate it very much. Thank you in advance.
A continuous blinking light is usually an error code that can help a repair man track down problems. The only thing you can try to do is unplug the TV for about 4 hours and plug back in. If the blinking light continues, you'll need to have it repaired or replaced, depending on the age, value, and cost to repair.
