I have my XBOX 360 rigged up, and can see...Chinese! We understand you can change the language, but there is an obvious difficulty. Any suggestions? This has come about because the wireless controller was being played with prior to having the TV connected. Ooops ~ We've selected chinese (not guilty!), Is there any way we can we reset language?
-submitted by Michael O'Hara
As of now, I am not familiar with any kind of factory reset to revert things like language to "out-of-the-box" settings, or at lease Microsoft has not listed any way to do it in the manual or on their user support site. So, it looks like you'll have to do it the old fashioned, "step-by-step" way.
Lucky for you, the XBOX 360 dashboard is pretty predictable, so you should be able to navigate the Chinese menu without actually knowing what any of the characters mean. The tab on the far right is called the "System" tab. The lowest option on this screen is the "initial setup". Select it to run the first time setup again, and the first user selectable option should be language. Once you get it back to English, finish the rest of the XBOX 360 setup.
Did You Know...
Playing games on conventional CRT TVs and Plasmas can eventually wear static images into the screen. However, with a few precautions up front, you can mimimze your risk. Read "Does playing video games cause permanent damage to your TV?" to find out more.
Ever wondered what the differences are between the different game consoles on the market today. Read "The Playstation 2, XBOX, & GameCube" to learn more about them.
While You're At It...
Is your TV image reddish/bluish when viewing component video sources like DVD or HDTV? If so, you'll want to read "What To Do When Your DVD/HDTV Image is Reddish/Bluish" to solve it for good.
Nothing is more fun than playing your friends on multiple TVs in your own home, and all you need to do is setup an XBOX LAN. Read "Setting up an XBOX LAN" to find out how.
