Mits WD57731 Solid Red Status Light
10 posts / 0 new
JohnnyK-Okie
JohnnyK-Okie's picture
I have a 2007 Mits DLP model # WD57731, status light is solid red, won't power up, tried pushing reset button, nothing.  Called Mits support, was told lamp burned out, could order from them for $179, checked ebay, ordered, $80, installed, double checked lamp door, but no change, status light solid red, no power, no screen.  Looked on forum to see how to retrieve error messages, but didn't find it.  Any help would be greatly appreciated, thanks in advance.
evil
evil's picture
Try holding menu and device
Try holding menu and device on the tv untill it gives you one.
JohnnyK-Okie
Thank you for the reply and
Thank you for the reply and advice. Held Input and Menu together. Status light stayed solid red, however, timer light blinked green - 5 times, 8 times, did 5 sets of 5 and 8.
So what does this mean? Thanks in advance to all.
JohnnyK-Okie
Signal short, now what? How
Signal short, now what? How do I troubleshoot that? Just Joe Homeowner here, be pretty mechanically inclined. Thanks again.
evil
evil's picture
Good question, I'm not
Good question, I'm not familiar with that code my self as it is a newer model. But it sounds as if there may be a short on the signal board. I can forward this to other techs on here and see if they are more familiar with it. At the very least your armed with enough info to ask techs in your area if they are familiar with it and possibly what some of the common faults for that error.
JohnnyK-Okie
Many thanks Dr. Evil for the
Many thanks Dr. Evil for the replies and forwarding along to other pros. The unit is quite old, purchased in 2007, I believe. Thanks again, happy holidays.
msprecious
msprecious's picture
So did you ever get your
So did you ever get your television fixed? I am having the same problem you had. Could you please help?
rasco
rasco's picture
Toshiba model no. tp55h95 the
Toshiba model no. tp55h95 the screen goes blank and the red light on the front blinks if i unplug it and plug it back in the picture comes back but sometimes it will take several times to stay on
rasco
rasco's picture
found that i can play dvds or
found that i can play dvds or ps3 and the screen stays on (going to try another input for the tv)
msprecious
Well I found out what my
Well I found out what my problem was, took me a little bit of research. The problem was the signal board went bad so I pulled the board out searched for the board number on ebay and got a refurbished board for 50.00 works perfect now.
