Tips for Choosing a Good DVD Making Progam
1 post / 0 new
whlalala
whlalala's picture
The first point: Compatible with almost all popular video formats.
I bet that nobody want to use a DVD creator which is weak in most video formats or it can not import and convert nothing but MP4, AVI, WMV.
With uSeesoft DVD Creator, you won’t have to worry about this for it can import and convert almost all popular video formats like 3GP/3GPP, 3G2/3GP2, MJPEG, AVI, DivX, Xvid, MPG, MPEG(MPEG-1/2), DAT, FLV, MKV(Matroska), QuickTime(MOV,QT), MP4, M4V, WMV, ASF, MPEG-4 AVC, DVR-MS, H.263, H.264, X.264. It will probably meet your need converting and burning videos to DVD.  The second point: Concise and fresh interface.
You know how irritating it occurs to you when you want to make a playable DVD disc with a complicated-interface software. So for a freshman making DVD disc or DVD files, a DVD creator with a understandable, easy and concise interface is quite important.uSeesoft DVD Creator is just the right choice for you to choose.
With a simple, concise and fresh interface, you can easily start to make your own DVD with the DVD Creator. The main interface contains four functional tags including ‘Source’,’Menu’,’Preview’,’Burn’. These tags clearly show you the steps of making a good and professional DVD. First you need to import source files to make titles which are needed to built the main part of DVD. Second you will need to make a DVD menu to make your DVD look more professional and nicer(Also, you may ignore this step if you need no menu for your DVD and want to burn to DVD disc directly). After you’ve made necessary settings for your DVD, you can watch the slideshow of how your DVD will be in the ‘Preview’tag. If you have checked all the steps and made sure there is nothing to be modified, you can skip to the last tag ‘Burn’ to make DVD. So how easy and convenient a concise and fresh interface is for you to make DVD.
 The last point: Powerful for you to customize your DVD.
It is rather boring that some DVD creator wouldn’t allow you to import your own favorite images or music to make background image or background soundtrack. You can only use the horrible preset images or music for your DVD menu. But this DVD Creator will help you customize your DVD menu! You can import your own images to make your own beautiful background for DVD menu and add music of your own taste into the creator to make background soundtrack. Also, if you are kind of the lazy who want to make a quick DVD menu, you are welcome to use the preset images and music in the creator.
Besides create your own pretty DVD menu, you can easily edit your files by cropping your files for best screen size or cut off black edges, trimming your files to get rid of the worst parts of your files, changing the effects of your files and adding text or image watermark into your files.
Download to have a try here
