error code 23 mitsubishi 65" ws-65819
9 posts / 0 new
JW HELP ME
JW HELP ME's picture
I HAVE A 65" MITSIBISHI TV WS-65819. THE TV IS ABOUT 6 YEARS OLD.
I TURN ON THE TV BUT IT WILL NOT POWER UP.
I DOWN LOADED THE COMPLETE SERVICE MANUAL FOR THIS UNIT.
THE CODE FOR "2-3" IS A "HORIZONTAL DEFLECTION FAILURE"
CHASIS: V18, CONVERGENCE IC8C01 267P150010 HIC- STK392-570
I CHECKED THE PICO TYPE FUSES WITH A OHM METER ALL WERE OK. FUSES F9A01 - F9A06 MAIN POWER SUPPLY.
ANY HELP ON THIS MATTER WOULD BE GREAT
THANK YOU JOHN
ANY ONE KNOW WHICH CIRCUITRY BLOCK DIAGRAM THE PROBLEM MAY BE ON?
JW HELP ME
SORRY MY EMAIL
SORRY MY EMAIL              JWE@VTLNET.COM
Mzawsome
Mzawsome's picture
I have a similar problem. I
I have a similar problem. I have error 24 on my WS-55809. I believe that the STK392-570 could have problems. I have no blown fuses either. I think there is some internal problems with those ICs. I checked the pins 4 and 5 intermittently showed continuity and 14 and 15 on the other did the same. Let me know if you found anything out. I'll keep you posted as-well. God Bless.
saraschil
saraschil's picture
I also have the code 24 error
I also have the code 24 error with my WS-65819 TV. When you turn it on the green light stay's on for about 3-5 seconds then goes off.The relay on the power supply board clicks at this time. My thought was to replace the convergence chips and pico fuses, am I going in the right direction? Thanks
evil
evil's picture
Check for coolant leaks on
Check for coolant leaks on the boards. I can give you a link to a complete repair kit If you need it.
evil
evil's picture
Click HERE for the repair kit
Click HERE for the repair kit you are looking for.
saraschil
saraschil's picture
error code 23 did the
error code 23 did the Mitsubishi WS-65xxx Convergence Repair Kit solve your
your problem
evil
evil's picture
I believe your chassis is V19
I believe your chassis is V19 error code 23: is loss of horizontal deflection. It is common for this error to be caused by the FET or MOSFET that drives the flyback transformer. The link I provided for the previous guy will not fix your issue however I can provide you a link to a repair kit that most likely will. If you have a soldering iron and a manual remove the Horizontal Output Transistor or HOT and take it to be tested by someone who repairs electronics and make sure it is bad before replacing, they may possibly have a replacement there. There may also be some fuses that are bad, but if you install the new HOT and need further help feel free to write back. Also google images of "Horizontal Output Transistor or HOT" and flyback transformer to get an idea of what you are looking for on the boards of your tv. You will be working WITH very dangerous amounts of electricity so use common sense and safety measures as well as any knowledge you can read about.
Clay72
Clay72's picture
I have a WS-55807 Mitsubishi
I have a WS-55807 Mitsubishi PTV whose. Power and timer light stays on only 1 or2 seconds. Thought it might be the pico fuses. Took the board out. Pico fuses tested in continuity. Put the board back in and TV powered up for approximately 5 minutes, but with only a blue screen with some faint flickering horizontal lines at the top of the screen. After it powered off, the same power off after 2 seconds of power occurs and the error code is a 23 indicating a horizontal deflection failure. Appreciate your thoughts or recommendations. Thanks!
