HELP....SAMSUNG HLP5063WX/XAA won't turn on after changing lamp
7 posts / 0 new
sally the camel
I changed the lamp in my HLP5063WX/XAA and reset the timer.  Once I tried to turn the system on, it doesn't do anything....no sound, no picture....only the standby and lamp lights blink.  Has anyone ever encountered this problem?
MOtvGuy
You've either got a bad
You've either got a bad ballast or a DMD board.
sally the camel
MOtvGuy said: You've either
MOtvGuy said: You've either got a bad ballast or a DMD board.
Thanks.  I've decided to go ahead and call a repairman.
Good choice Sally. Let us
Good choice Sally. Let us know what you find out. Good Luck
db1234
I replaced the lamp but all 3
I replaced the lamp but all 3 lights (stand by/timer/lamp) lights are blinking...what 2 do next? Replace the ballast? What are alternate options?
Double check the lamp
Double check the lamp installation and make sure the lamp access door is secured properly
Larry D.
Marko1
You must replace the back
You must replace the back cover of the set and the door to the lamp. There is a safety switch that must be pushed up by the lamp door or else the TV will not turn on.
