I have a ws-65513 and it has a constant green blinking light. Can you send me the service manual along with the documents on how to repair the DM Board to [email protected]
Larry, I have a ws-65513 with the same blinking light problem. I have tried cycling power and pressing the reset but it just keeps blinking. Would you send me the service manual and instructions?
I just had a power outage and my WS-65513 power light is blinking just like everyone else on this thread. I have my manual, but I need the repair documents. Thank you in advance. [email protected].
I am getting 3 short blinks and 1 long on my Mitsubishi VS 60609 TV. Can someone help me or send me repair manual so I can look up whay this code means.
I too am plagued with the green blinking light on my ws-65513. Would you please send me the repair information as well. It's NFL and NBA season...Help!
The best advice I can tell you is to go to tvrepairkits.com and order the blinking light kit for your model of set, the kit comes with the high temperature/ high frequency/long life 105 Celsius type capacitors (not those cheap Radio Shack caps) full easy to follow pictorial directions, AND free live on-Line tech assistance in case you run into a problem, all kits are shipped out within 24 hours in most cases, 2 to 3 day Priority mail. GOOD LUCK!!!
Larry Dillon, tvrepairkits.com-senior repair tech
Asa and Kurt,The best advice I can tell you is to go to tvrepairkits.com and order the blinking light kit for your model of set, the kit comes with the high temperature/ high frequency/long life 105 Celsius type capacitors (not those cheap Radio Shack caps) full easy to follow pictorial directions, AND free live on-Line tech assistance in case you run into a problem, all kits are shipped out within 24 hours in most cases, 2 to 3 day Priority mail. GOOD LUCK!!!
Darryn, to where? You left no information man. You need to leave an e-mail address.
i am so sorry i did not leave an email address.....it is [email protected]
Thats a little better. I will send you out the service manual as well as the documents on the repair of the DM board.
Hey Larry, Can you send me the info to fix the dm board on my tv. My e-mail is [email protected]. Thanx, Rudy
What's the model number of your TV set rcj?
Thanks For all Your Help,
Chad
Chad, the repair docs are on their way! Good Luck with your repair.
please send repair manual [email protected]
thank you
Hi, can you send me the service manual for Mitsubishi WS-65513 to [email protected]
-Thank you
Hi, could you please send me the service manual for the Mitsubishi WS-65513 HDTV to [email protected]
-Thank you
I have the blinking green led please email me the fix
Thanks [email protected]
could i also have the manual and instructions on replacing the caps on the dm board for the mit 65813. thanks. [email protected]
same problem here. WS-65513 green timer blinking problem. Can you also send me info on how to fix. Thanks so much. email is [email protected]
hi i also need the instructions and service manual for ws65513 for fix of blinking green
thank you mike
same problem greeen blinking light mitibushi ws65513 please send repair info thanks john
i have the same green light problem on my ws-65513 my email is [email protected]. i would greatly apprechate the help
thank you carl
i have the green blinking light problem on my
mitsubishi ws-65513 my email is [email protected]. please help. Thank you
I had same problem with my tv. please send me the manual [email protected]
Thank you
Thank you
Mr. Dillon,
Please also send me the repair instructions for WS-65513 bliking green light/won't turn on. [email protected] Thank you
Can you send me the instructions and service manual for the WS65513? Also, what caps do you recommend?
nbagadioATgmailDOT.com
Thanks a ton!
NB
Another victum of the blinking green light... Help Can you send directions to fix it myself please
Kurt
I am a victim of the blinking green light. It's NFL and NBA season, please help and send me the information on fixing this.
Asa
Asa
