Harman Kardon receiver
7 posts / 0 new
xidui
xidui's picture
When I turn it on, it blinks couple time and turn itself off.
 does anyone know how to fix this?   Please help....
 thank you!
Matt Whitlock's picture
Hi Xidui,
Hi Xidui,
This indicitive of any number of problems. As a first troubleshooting step, you'll want to disconnect everything from the receiver, unplug it from the wall for about 10 minutes, plug back in, and try to turn on with nothing attached. When you do this, does it still shut down?
PETE
PETE's picture
yes, I disconnected
yes, I disconnected everything.  It's been sitting by itself for several months.
When I turn it back on, it turns on for 3 seconds then off again.
 Please let me know if I can do anything else to test ...
dans_repair_service
dans_repair_service's picture
Most likely you have shorted
Most likely you have shorted outputs.  The unit detects the problem and shuts itself down.  This is what is known as protect mode.  If you have no experience with electronics, it may be a bit difficult to walk you through this.  But at the very least, I need the model number.  That will give me a clue as to what you should look for.  Please provide this and I'll try to help further.
Dan
PETE
PETE's picture
dans_repair_service said:
dans_repair_service said: Most likely you have shorted outputs.  The unit detects the problem and shuts itself down.  This is what is known as protect mode.  If you have no experience with electronics, it may be a bit difficult to walk you through this.  But at the very least, I need the model number.  That will give me a clue as to what you should look for.  Please provide this and I'll try to help further. Dan
Thank you for helping me....
The model # is AVR 25II
Thanks Dan ...
sweepy
sweepy's picture
I have the same problem with
I have the same problem with my hardan karmon reciever model no AVR130 . we are stuck in "protect" mode and then the unit switches off.  Anything i can do at home myself.
Jesus921
Jesus921's picture
I have reset my Harman kardon
I have reset my Harman kardon main reset",disconnected the unit nothing attached to it ..It comes on then says protect......
