Mitsubishi ws-65611 problems
99 posts / 0 new
of course! I do but I need
of course! I do but I need your e-mail address.
Wyatt E
My email is [email protected]
I have been poking around and it seems it is the DM module, which I pulled out and opened. Visually everything looks ok, even the 7 caps on the power board (not bloated or leaking), but that doesn't say much. The blinking green light continuously flashes, which indicates the DM isn't booting up but the TV's microprocessor is. Just wondering, in your experience, where would be the first place to look on the DM? Thanks for all of your help!
you should change the seven
you should change the seven caps even if they look good!!! if that does not work probably the EP-2 board inside the DM is bad
Wyatt E
What does the EP-2 board do?
What does the EP-2 board do? There is another problem, though it may be unrelated. At some point I actually had to disconnect the front panel controls to get the set to come on, but I don't know if that's in any way related. Now, even with the panel disconnected, it refuses to power up. When this happened a couple of years ago, I left the set unplugged for almost 3 weeks, and much to my amazement it would power on. 1 or 2 weeks wouldn't do it, but only after 3 weeks would it work. But now, it's reared its ugly head again and I'm growing impatient and just want to fix it.
jstanbary
Model: Mitsubishi WS 65611
Problem: Blue element showing arch in middle and text is echoed in blue below original text. I believe I need to replace the blue element, but can't find a vendor to order it from. Any ideas? My email address is [email protected]
Tip: To check to see if a remote is working, turn on a video camera and press the button on the remote to see the infrared light(s) are working.
Larry Dillon: Please help!!!!
coleolster
I have the same problem with
I have the same problem with the DM board (tv's volume went up by itself and wouldn't respond to the remote). Please send me the repair instructions/repair manual for WS65611 TV.
Thanks.
Wyatt E
The caps have been replaced
The caps have been replaced on the DM board, but my set still fails to turn on. You had mentioned the EP-2 board, but there's not that much to it. What does that board do exactly? Thanks again!
that board as I understand it
that board as I understand it is the memory board for the DM board.
bronson
Larry same problem with my ws
Larry same problem with my ws-65611 repair guy said it was the dm box. is that a pain to repair
jaipar
Hi Larry i've exact same
Hi Larry i've exact same problem it Ws-65611 TV shuts off automatically after few hours of use and would not come on unitil I wait for abt 15-20min and would run for another few hrs and shuts off again.Could you please e-mail me the service manual & related fix pictures for cap change.. thank for your help...
Eddie007
Ding it! Lots of people
Ding it! Lots of people having problems with the Mits tv's. I have the WS-65615 with same flashing green light of death. If any of you have been successful in repairing this problem shoot me an email with the how-to-fix-it introductions. Thanx for the help. [email protected]
Eddie007
how you all doing? i see
how you all doing? i see lots of you having problems with the same Mit's tv's. I have the Mits WS-65615 with the same green light of death; such a pain in the behind. I swear sometimes I want to set it on fire in the back yard and see it burn, baby burn! If any of you have been successful at fixing this crappy tv set shoot me an email with the how-to-fix-it instructions. [email protected]
Thanx for your help
quick fix
You may want to just try and
You may want to just try and disconnect the front panel. Take off the speaker grill covers and unscrew the wood panel (if not under warranty do not worry about the warning). follow the front panel wire and dissconnect. Once i pluggeg it back in, the problem was fixed. If the volume button always goes up, your TV will not accept another command so that is why the other buttons and remote do not work.
rmoblley
Hi, guys! I had a very
Hi, guys! I had a very similar problem... remote didn't work, only On/Off on the TV worked and also when the screen did show, the device menu was showing and cycling continually around the feeds without selecting any (it happened to be on cable, so behind it I got a cable picture). System reset 3 times, no luck. Un plugged TV over night and still same problem. Any suggestions?
BevJ
Larry - So glad I have found
Larry - So glad I have found this site. I posted under another topic but the model number for my TV is WS65611. I too have had the same exact problem that the first person posted about the volume and everything but the other day are power went out and now I have the flashing green light but tv won't come on at all. Repair man came out today and said we need a new DM Board $500.00 YIKES which I can't afford. Is there a easy cheaper way to fix this. Thanks Bev email: [email protected]
The best advice I can tell
The best advice I can tell you is to go to tvrepairkits.com and order the blinking light kit for your model of set, the kit comes with the high temperature/ high frequency/long life 105 Celsius type capacitors (not those cheap Radio Shack caps) full easy to follow pictorial directions, AND free live on-Line tech assistance in case you run into a problem, all kits are shipped out within 24 hours in most cases, 2 to 3 day Priority mail. GOOD LUCK!!!BE SURE to get the extended kit. Good luck
the cable guy
larry, about this power thing
larry, about this power thing with the on for 2 to 3 secs and then off, i am working on a friends and i have found the fuses but what do the convergence ics look like and where can i order them? i already did the 7 capacitors in the dm board. i had the blinking light problem with mine and that fixed it. theres will stop blinking and turn on for 2-3 secs and then cut off. please help. i am trying to save them some money. thanks and i you could email me that service manual i would greatly appreciate it.
HelpFixMyTV
Hello,
Hello,
I had a local tech came out today to change all seven caps on my ws65611, but the green light problem still exist. He left pretty much gave up on my TV. After reading a bit on this forum, I found out that there is a code for my TV set. It is 33, could anyone tell me what this code is. Thank you in advance for your help.
Zebrakhan
Hi everyone .I have
Hi everyone .I have Mitsubishi WS-65611 . I have the problem with the blinking green lite after power failure . I checked the seven capacitors they are reading two of them 2000 mf the other two 2000 mf and the other tree 2600 mf ( I messured them without taking them out ).
Visually they look good . Do You think they are OK . On the power supply I have
25 V , 12 V , do not have 5 V and 3 V . Is this normal ? Can someone send me a diagram of the DM Power supply please ? Any suggestions ? Thanks a lot .
Vanio
Zebrakhan
I checked the two voltages
I checked the two voltages after take out the power circuit board and applying 12V to it externaly (other source ). I have the 3 V and 5 V . What do You thing the problem could be ?
Zebrakhan
The power board where the
The power board where the seven capacitors are .
Vanio
Terio
Hello everyone,
Hello everyone,
I have an issue. I have a WS-65611 and the green light is blinking. I have tried to unplug and plug the tv back in but it still is blinking. from what I read it could be the capacitors. I was wondering if anyone had the service mannual for this model or if any one could help me out.
Thank you,
Teri
Steivn
I have the Mitsubishi WS
I have the Mitsubishi WS-73909 last march I had the green flashing light and replaced all 7 cap ( Yes the 73 is a little diffrent from the smaller ones that I think only have 4 ) anyway today I turned off the tv by acct. and tryd to turn it rite back on the green light comes on I hear the click then it tures rite back off it will do it if I try it rite away again , but if I attemt it a 3rd time it makes me wait a few moments. I held down the menu/device to get a code and what is shows is 2 fast flashes then a pause before flashing 2 times again it does this for 10 reps of 2 quick flashes. Can someone please assist with any ideas or fixes.
Steivn
Steivn
I now get a differnt code *-*
I now get a differnt code *-** *-** *-** *-** *-** I hit the reset button and now the code is 1 blink pause 2 blink it does this 5 time. Any one have a Idea? Please help
Thanks again
Steivn
Steivn
Ok back to the 2 flash 10
Ok back to the 2 flash 10 repeat mode, someone please help
Thanks again
Steivn
sorry no such code check it
sorry no such code check it again the 2 is correct but not the 10!
Larry D.
stevin what I seen you post
stevin what I seen you post abouve sounds like a short and most likely it is the convergence ic's?
Larry D.
Steivn
Thanks for the quick
Thanks for the quick responses yea I just checked it again it flashes 2 x and repeats 10x (convergence ic's?) I never had a problem with the convergence but then I mite now =c( where are they located I just pulled out the big box inside won't go any father rite now ( maybe direct me to a place where it might have a picture I followed one of the links you posted in another forum but they had so many listed I could tell what I would need are they located in the big box?
Thanks again Larry
there should be copy of a
there should be copy of a service manual for this set in the technicians corner if not I will upload a copy you go to the home page click on the resource tab then technicians corner then click where it says view all.in there it will show a chassis layout so you will see where they are.
Larry D.
