Zenith big screen tv repair
4 posts / 0 new
nemmer
nemmer's picture
I have a Zenith big screen TV-- mod#PVR5263RK, that has no power. The 4 amp fuse was blown.  The bridge is bad and resistor R3267 was burnt. I need the value of the resistor, it's a 1/2 watt one. It's in the power supply section of the pcb (204-2969-06), right in front of the fly back. If anyone can assist it would be appreciated. Thanks in advance.
nemmer
nemmer's picture
The only numbers I can find
The only numbers I can find on the pcb are:
204-2969-06
cpc-e 94v-0
9516
I hope one of these numbers are what your looking for. Thanks in advance.
Larry Dillon's picture
There should be a module
There should be a module label somewhere on the back or inside the cabinet on the sides. This will thell you the numbers I need to look this up.
nemmer
nemmer's picture
found it.
found it.
SMPS/Sweep
9-1302-07
Thanks.
