sony KP-51WS510-convergence ic-help
936 posts / 0 new
mathelm
The "D Board" for that model
The "D Board" for that model is a A1302180A and a quick glance at this thread would have told you that that board is no longer made and almost imposable to find.  With the right tools, which in my case involve a magnifying glass, anyone can do this repair.
Please note that while Larry is one of the best assets of this boards, much more so than mathelm is or wants to be, mathelm is the one who keeps that spyware plagued ( as they all are ) Pando installed on his computer in order to keep sharing this manual.
This sure sounds like one of my more negative post.  Oh well, must be one a those days.  Heres a nice smiley face  Laughing...... there,  that's better.....
lochkelly
Thank you for the manuals
Thank you for the manuals Mathelm, I will let you know how everything goes when I finish the repair.
mathelm
I may try and make a youtupe
I may try and make a youtupe video of soldering, testing the embed feature here.
phil
Larry Dillon said: You will
Larry Dillon said: You will need to make sure you get some heatsink compound and dont forget to apply lots of this compound to the metal back of the new IC's before you remount the new IC's to the heat sink. Also you should change both of the IC's because as sure as your born, the other IC will fail a month or so down the road and you will again be back inside the TV set changing the other IC, so it is best to change both at the same time. You might have small feedback resistors burned but most of the time, you only have a problem with the IC's. you also may need the service manual to do touch up alighnment in the service menu as you should never attempt any service manua alighnments without a service Manual. But I have goos news and can save you 25 bucks! Just leave your e-mail addy and i will send you a copy of it for free! You will need to go to pando.com and download this proggy as this proggy lets you e-mail and accept large e-mail files as the service manuals are large files. This is the only way i can send large files via my internet provider. Good Luck and Do let us know how you make out with this repair.
hi could you send me a copy need to change ic board on kp-51ws510 not good with soldering, it would be great if u could help
thanks Brian
phil
Larry Dillon said: No you
Larry Dillon said: No you should brush it out carefully with A small brush and a vacuum cleaner.  If you purchaced good ICs and used heatsink compound, the IC's should last you.  Good Job on this you saved yourself big bucks!
Help larry dillon can you please send me that link for service manual have sony tv kp51ws510 with convergence problem need to change ic,s my email [email protected]
navbob
Larry Dillon said: I sent
Larry Dillon said: I sent the manual to you.  it is the same chassis number for your TV set.  Thats the RA-6. good Luck
Could you PLEASE email me a copy of the service manual at [email protected]  Thanks a lot!
ann84
I had a bestbuy tech come out
I had a bestbuy tech come out to diagnose my Sony KP-51 after it made a loud popping noise and died. I have the PSP extended service. He said he would have to order a "power triple pack" and the "d" board. He said he wanted to have both on hand in case the other had failed as well. So far, two weeks later, after calling and finding out that the repair dept had no record of parts being on order, I get a call back and am told that the parts have been ordered and that it took time for Sony to "research" the parts and get back to them. So it's obvious that the "D" board is no longer available. I did a quick google search, this site and another for Sony parts, and found that out in 5 minutes. I don't know what a "power triple pack" is. I see that there are several lettered parts, "A complete",  "G" complete, etc. Since these are the most costly, I would think that these may be the components that comprise the "Power Triple Pack" the tech was referring to? On one hand I'm glad I have the PSP, but seriously, I'm going into my third week without my TV. Any opinions as to the possible success of the repair with the parts that the tech is going to install? Wonder what he's going to say when he shows up without the "D" board. My service plan expires this month and have received a renewal notice. 3 years for $400.00. My original plan was $250.00 for 4 years.  How much life do you think I'm going to have with this TV? Or should I just invest in a new flat panel? Thanks for any input. George
lochkelly
I have change the two STK'S
I have change the two STK'S and one link fuse and my television is working great .Have no problem for two weeks now. Thank you all very much for your info that help me fix my t.v. Will recomend this site to anyone,great job everyone.
mikeandsylvia
I was wondering if someone
I was wondering if someone could please e-mail the serivce manual for a sony KP-51WS510
my e-mail address is [email protected]
I already have Pando installed
firewalker
I have a KP-51WS510 that's
I have a KP-51WS510 that's just started the red convergence problem. :(
Could someone please email me a copy of the manual to [email protected].
Thanks!!
Joe Curwick
I am also looking for someone
I am also looking for someone to email me a copy of the service manual for the KP-51WS510. My email address is [email protected]. Thank You
veteyedoc
I had the same convergence
I had the same convergence problem with my Sony as well. I have replaced the IC's but the problem is still there. I think one of the pico fuses are blown - there is one yellow one that does not respond on the amp meter. I have been trying to find the 3.15 amp pico fuses, but have not located one anywhere on the internet. I had heard some people were using 4 amp fuses, can I do this?
 Thanks for any help,
veteyedoc
rupert maxwell
a2z said: Larry Dillon said
Wow, talk about convenient.  I turned on my set yesterday and have the same problem with my KP-51WS510.  I have component level electronic repair experience and use to fix TVs back in the day.  Larry, could you send me the service manual also?  Also, where is a good place to order those ICs inexpensively?  I have some heatsink compund that I use for computer CPUs.  Will this work for a good heatsink coumpound for the ICS? Thanks in advance.
Larry:  your post is a Blessing.  My sony went west last week with the same problem as those listed.  Please tell me, what is the cost of the two ICs?  and where can I get a copy of the service manual?   I miss my picture and would love to have it operating by christmas.   Thanks in advance and GOD Bless
rupert maxwell
tlj000
Hello mathelm
Hello mathelm
think you could could help out another poor sony owner
I could use that manual
Thanks Tim    [email protected]
mathelm, thanks for helping
mathelm, thanks for helping out here man! It is really appreciated.
jwsenecal
Hey Larry I've read all your
Hey Larry I've read all your comments about the convergence IC's for the Sony KP-51WS510 and it looks as though you have access to the service manuals. Could you please email me the manual I'm gonna try and save a buck and replace them myself. Set just is 2 months off the 4 year warranty and the problem started.
jws, it should be on its way
jws, it should be on its way to you very soon. Good Luck
mathelm
Thanks Larry, right back at
Thanks Larry, right back at ya.  You're the reason I'm getting to watch in HD, Romo and the cowboys beat up on everybody this year.
How bout dem cowboys......
Hope we didn't double send the manuals to jws there...
I guess we did man. Nawww,
I guess we did man. Nawww, Miami will beat the BOYS Big time this year! I lived in florida most of my life. I have no choice to want them besides the NY Jets! LMAO.
Boomer Sooner
Would you be able to send me a service manual for a Sony KP 51WS510?  Would anyone happen to know what D board and/or IC's I would need...the tag on the back is labled as RA-6A if that helps.
My email address is: [email protected]
mathelm
Manual sent via Pando.....
Manual sent via Pando..... just read above and it will answer all questions...
jjhuse
i just traded a broken
i just traded a broken vehicle for a broken tv. he told me to replace the convergence ic's. it is a kp51ws510. ok with electronics just not delt with tvs to much. the problem is the red blue green are all side by side and the picture does the bow tie thing was he right or is there more?  the board had the d on it but it is crossed out and an f stamped on it. does the mean anything. is there adjustments in the menu or is it for sure the ic's. new to site just looking for advice. he gave me a service manual with it. but have not looked at it to much. thanks in advance for your help.
Yes, you need to replace the
Yes, you need to replace the two convergence IC's in this beast. I have sent you a couple of links that will help you repair the TV set as well as explain how the adjustments are made on this TV set. Good Luck
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
mikeym
hey guys thanks for all the
hey guys thanks for all the help with convergence prob. ive been reading this for a few weeks and finally maned up and replaced ics myself (teedius?)the picture is about 95%. ill do some fine tunning with all the info here. heck with paying $600 to have repaired . i can electricute my self no prob. abig mag glass is helpful too
jjhuse
i checked the pico fuses
i checked the pico fuses under the heat sinks i think anyway they are pinkish 2 under left and 4 under right they all seem good so maybe just ic's bad  have not checked g board yet i will get parts after xmas and get back on progress. from what i understand it is hard to get d board is there still somewhere i can look?  what does it mean that the d is crossed out and f stamped next to it? thank you very much i will get back soon
zapdbf
"what does it mean that the d
"what does it mean that the d is crossed out and f stamped next to it?" - nothing that is important to us, most likely it was somthing that was marked on the board durring production.
"from what i understand it is hard to get d board is there still somewhere i can look?" - sony does not make the board anymore but a company called pts may still referbish them. you can try there.
www.ptscorp.com
jjhuse
thank you zapdbf i will
thank you zapdbf i will update on how it went after xmas thank you all for yuor help
Bkodriver
HI All,
HI All,
I have the same problem as described, could someone please send me a copy of the manuals?
bkodriver (at) gmail (dot) com
Brian
Randy Cariveau
Chuying said: I bought a
Chuying said: I bought a KP46WS500 Sony TV, 4 years and 20 days later, it had the problem with red out of convergence. I bought the coverage for 4 years and they will charge me $100 to take a look and plus labor and parts. I found this site and read through comments and decide to fix it myself. I downloaded the menu ($15), bought a STK392-560 ($33+$10 shipping), and about half day of work, the TV is back to normal again. I had chance to adjust the focus and clean up the lense, I think it works better than ever before.
I have the same problem with the red being out of convergence on my Sony KP46WT510. I would like a service manual. I have called Sony service repair and they are charging $400 plus parts for a service repair. What part would I need? I also don't have any confidence to replace this part myself. Any suggestions?
