Mitsubishi WS65613 Light blinking
612 posts / 0 new
starnz
starnz's picture
Larry - you're becoming a one
Larry - you're becoming a one-man cottage industry!!!  You're help is greatly appreciated.  I have a Mits WS-55909 with the blinking timer light problem and want to try the DM board capacitor fix.  Please, could you send a copy of all related repair materials to me at vanfindley@comcast.net.  Many thanks.
vanf
steve16
steve16's picture
RE:( If the TV does NOT blink or show any problems when the volume is turned down all the way, most likely, this is not going to be your problem. But if the set only acts up with the volume turned up,  there is a capacitor, C9A58 in the main power supply that needs to be check and replaced. This is your 17 volt line that is feeding the b+ to the audio output IC. The Power supply is on the same board that has the convergence ICs on them. This IC is standing up on a heat sink and is marked on the board as being IC3E01. If you change the capacitor, and the same problem occurs, replace the audio output IC. First though, measure that 17 volt line with the volume down, then with the volume turned up a bit.  Make sure none of the speaker wires came off and are shorting against anything, as this would also cause your symptom.)
 What size is the  C9A58 capacitor? What IC IC3E01 do I need to purchase as well? I wish to order it before I do the work.
The sound can not be turned up or down with the remote control  now. It is at one level.. barely audable. If I try to manually turn the volume up from the tv it blinks then goes down to the low level.
Please help obe wan kenobe...
Resume Writer
Resume Writer's picture
Got the parts and did the fix.  TV is working fine now.  Your instructions and diagram pictues were great.  Thanks for your help.
Paul
Phoenix Arizona
ps - If you need the capacitors in the phoenix area, the only place that has them is Capital Electronics
Bercreaup
Bercreaup's picture
Hello, I have read all the
Hello, I have read all the posts regarding the "infamous green blinking light" and all I can say is HELP! I too have that problem.  I have a 65" widescreen Mitsubishi projection tv.  Can you please refer that info to me at pinkroses889599@yahoo.com.  Much appreciated.
Larry Dillon's picture
Todd, you need to
Todd, you need to troubleshoot the set I'm afraid. Go by what i have told you. Those parts I said MAY be bad, not for sure. You need to do some voltage measurements. If this is something you feel uncomfortable with, I'm afraid you have gone as far as you should.
steve16
steve16's picture
I do have a meeter.  What size is the  C9A58 capacitor? What IC IC3E01 do I need to purchase as well? I wish to order it before I do the work.
Thanks!!
It might not be your problem
It might not be your problem man. test the voltage first and find the capacitor in the power supply. Thats not how you repair a TV set by replacing parts to see if that is the problem. If you do it this way, you will spend 100 times more then if a pro did it.
steve16
steve16's picture
What voltage should I test
What voltage should I test for on each?
Check the 17 volt line and
Check the 17 volt line and the 22 and minus 22 volt line and the 135 volt line. all in the power supply. Make sure one or all do not go up and down drasticly when you turn up the volume.
starnz
starnz's picture
Larry -
Larry -
I need your instructions and materials for the Blinking Light of Death fix for my Mitsubishi WS-55909.  Can you send them to me at vanfindley@comcast.net?
 Many thanks for your help!
Van F.
adrock_30303
adrock_30303's picture
Porsche356A said: I also did
Porsche356A said: I also did the 4-capacitor replacement. I couldn't find the Panasomic 1000uf recommended, but ordered 493-1287-ND from www.digikey.com. These are the identical size of the ones in my Mitsubishi 65613. I found that I had to use a very high temperature to desolder them while wiggling the capacitor. The new ones went in fine. When I powered it back up, all seemed perfectly fine, and the picture was brighter than it had been in a long time (cleaned the lenses while inside the case). A couple of hours later, it suddenly reverted to its former bad behavior by suddenly going dead slient with no picture, but a solid green power LED. I powered it off and back up, and the picture was back, but every hour or so it continues to turn off the video and sound. So, I replaced all 4 capacitors again, with the identical result. Anyone have that same problem? Or know where to go next?
I'm experiencing the same problem as Porsche.  I've replaced the 4 caps and the set will display a picture and produce sound for a short while before the picture and sound disappear; however, the green light stays on and is solid.  Anyone experience this problem?  Wishin I was as lucky as most of you and been able to fix the set by replacing the caps.
marpat
marpat's picture
Larry, yet ANOTHER blinkin'
Larry, yet ANOTHER blinkin' green light!  Our Mit WS65813 has been giving me fits!  Could you please send me the info?  Thanks a "brazillion"! <chuckle>
PapaDean
Sun City West, Arizona
Grandpabauer@yahoo.com
Papa andVan, I have attached
Papa andVan, I have attached the documents you should need to attempt the repair of your TV set. I have also attached the original factory service manual so you can see ho the set comes apart. Good Luck with your repair.
raven, I am sorry the repair
raven, I am sorry the repair did not go as expected. There are many factors involved when doing this repair. There could be adittional bad capacitors in the power supply, or perhaps a problem with the power supply regulation. These are things that a novice would not be able to repair and these should only be handled by a pro.
Porsche356A
Porsche356A's picture
I finally invited a TV repairman in, and using a spray can for localized cooling when the sound and picture went away, he found a failing $20 IC in the power board. The invoice for this shows IC9C25, a 9-volt Regulator as the culprit. The specific part number is 270P677030. The total cost, including hauling in my 53" HDTV to their store, diagnosis, and parts replacement (desoldering the old part, replacing it with the new part) was $333. Good luck! I wish I had bought one of those cans of spray coolant; I certainly could have replaced it myself! The part is probably a $3 or less part. But, hey, I just love that 53" screen!
steve16
steve16's picture
Where could one get this
Where could one get this spray can for localized cooling ? I have the same issue..
stargates
stargates's picture
i have a tv 56613 that has
i have a tv 56613 that has the same problem flashing green light startrd 10/21/2007 would go off once in awhile than come back on. now just blinking breen light. hit reset still green blinking green light. tv is only 4 yrs. old. ws65613
grabbyzz
grabbyzz's picture
Last night we turned on our WS-65813 to discover the blinking power LED problem.  It is constant now and the unit will not power up.  Is the BlinkingTV.pdf from Chris@Chrisandnat.com sufficient in making this repair?  Should I request the complete service manual as well like others have done above in case there may be further problems?
My email is jonlaw78@yahoo.com
I feel very confident this fix is simple - my wife is excited to help with this today so we can get our picture back!  Then I may give this set to my parents and get me something larger but less deep ;)
Jon, I sent you the info you
Jon, I sent you the info you need to work on the TV set. Look at everything, take the back off of the TV set and decide what documents you need for your TV set. Good luck
steve16
steve16's picture
MCM electronics. fox
MCM electronics. fox electronics, Some radio shacks may even have it.
steve16
steve16's picture
From what I gather one needs
From what I gather one needs to spray a component and see if the volume level is normal going one by one until I find the culprit? What is the exact name of the spray product?
Freeze spray, I use one made
Freeze spray, I use one made by chemtronics. This does not alway find your problem however, only on sets with problems when you first turn them on then the problem goes away when the set warms up, or with a problem when the set warms up, a problem happens.
Kidder
Kidder's picture
In the words of Mr. Sudheer..
In the words of Mr. Sudheer.... which implies that the Mitsubishi WS65613 is a lemon
 I have a Mitsubishi WS-65613 started blinking green this morning and does not stop blinking and I cannot turn it on.
Can you please send me the instructions and service manuals to fix this infamous blinking green light problem.
 Please send the information to  : ordonezu@yahoo.com
O.D.
macgeek
macgeek's picture
 I have the infamous blinking
 I have the infamous blinking light on our WS65613. This sure sounds like a manufacturing flaw. I don't belive I have the skill set to solder on a board. We are in the Denver area. Does anyone have any recommendations on a service shop that is compenent that could perform this repair at a reasonable cost?
 Discbuild
hawker
hawker's picture
Wow, I can't believe how
Wow, I can't believe how widespread this problem is!
We too discovered the "Terrible Blinking Green Light of Death" on our WS-65813 when we got home from work.
Is it possible to get the repair procedure and service manual from you, as well, Larry?
Thanks in advance and I'm glad I found this site!
Mark in Mesquite
grabbyzz
grabbyzz's picture
I've replaced the four
I've replaced the four bulging caps but the light is still blinking.
grabbyzz
grabbyzz's picture
I'm confused where exactly
I'm confused where exactly they're saying this is:
 "While you have the board out, check with an ohm meter, the two surface mounted fuses on the side of the DM board opposite the capacitors. They are F9B00 and F9B02"
So what side exactly would that be?  The same surface?  Or the soldering side?  Confused...
grabbyzz
grabbyzz's picture
DOHHHH!  It works!  I forgot
DOHHHH!  It works!  I forgot to put back in the darn PWB-DEMOD card!!!
OK now to find the info on what is the right cleaner to use on the crt lenses and the other surfaces!
jon, they are on the solder
jon, they are on the solder side, they are maked on the printed circuit boards thenselfs. BIG yellow lettering.
