Hi Folks. I,m about to build an isolation tranformer from an old tube tv tranformer that i've got from a scrap yeard,
and connect it in conjunction with a Simple Series Power Limiter that i also built,put it inside the same box.
Now i'd like
your technical know how and help on this.Ok the transformer has INPUT-120v and three outputs, 126v,19v,17,now is it practical
to use this as a isolation transformer? also can i use a 2Mohms resistor from the primary to the secondary? and a 5 Amp fuse?also
could i use one of the other 17v.19v outputs to regulate the voltage? and build an ammeter?. THankyou in advance
Isolation transformer Progect
Mon, 12/11/2006 - 17:42
If youi connect anything to the primary, it will not be an isolation transformer, but a current transformer.
