Oh Okie dokie. First thing to try would be a lens cleaning disc. if that does not work, then it may need to be manually cleaned. Follow this and read it for that. http://www.techlore.com/article/14550/ If it still does not work then as it says in the article, once the unit is open you can see when a disc iss loaded does it spin freely? If it does your clamper and some refure to it as a Hat, is ok. If It wont spin on its own, then the laser is not focusing onto the disc and is most likly a bad laser assy and those parts will cost more then the unit to have replaced as its not something a consumer can replace as there are several alighnments, mechanical and electrical, that have to be done. Good Luck and let us know how you made out.
What type of DVD player is it and why do you thing think the HAT or spindle clamper needs to be repostioned?
