Mitsubishi CS-35MX1 problem
Storm
Storm's picture
The above television has the following problem. Upon power on, a blue line will be displayed horizontally across the center of the screen, turning 1/3 red, 1/3 blue and 1/3 green after a few seconds. The PIP board was removed and inspected and yes, the caps were corroded. The bypass mod was applied to the board and replaced in the set and had no effect. The board was then removed again, and the set powered up and the same problem was seen. The issue is there with or without the PIP board. My quick fix failed… what now?
Please Help…
Galiga
Galiga's picture
Any help out there for the
Any help out there for the Mitsubishi direct help?
Gma
Gma's picture
Storm said:
