Mitsubishi Projection TV Won't Converge With New ICs
1 post / 0 new
permanewb
Hey there. I've been reading around trying to solve my TV problems and ya'll came up more than once as a good source. So hello, and here we go.
I have a 1999 Mitsubishi Rear Projection TV, model VS-60803. I recently installed new Sanyo ICs I purchased from MCM. Unfortunately this only fixed the blue channel, red still won't converge. I checked the continuity of each pin just to be sure. They're fine.
I checked out the resistance of the resistors in the circuit as well. They all checked out, though I didn't remove them from the board... All the pico fuses checked out as well.
A final thing to note is that when I go into the convergence menus in the TV the text wiggles so much it's barely legible.
Does anyone know what I should check out next? This is a great TV and I would hate to give up if the problem can be fixed with a bit of soldering.
