I picked up this TV for $10 with the blinking light problem. The guy told me it worked perfectly a few months ago, but then it started taking longer and longer to turn on and now it does nothing but blink the timer light. The reset button stops the light from blinking until I release it, then it starts blinking nonstop again. I have it open and the DM module is out and I was surprised to see the capacitors on it are not bulged at all, though they could still be bad but I have no way to test them. I went ahead and ordered a capacitor kit just to be sure.
I also read here http://www.justanswer.com/tv-repair/2latv-mitsubishi-ws65613-rapid-flashing-green-light-every.html that I needed to check the standby voltages on connector KA. I found no voltage readings from all pins to check. This is now leading me to think there may be something wrong with the power supply. What should I check on the power supply?
