Mitsubishi WD-C657 Help Blinking Green Light
DemiSlayer
Ok so the other day i bumped the power plug while the tv was on and it powered off and on and off.
I tried to plug it into a more secure plug now i get a continuous flashing green ligtht
I have tried reset button waiting 24 hours
i ran the front diagnostics and it indicates 12 no faults detected
i took the tv apart and checked all fuses and capacitors of which are fine
any ideas?
DemiSlayer
Bump! could it be a regulator
Bump! could it be a regulator if so anyone know where to begin to check? thanks.
ChadH
I have the exact same issue.
I have the exact same issue. My WD-C657 has the blinking green timer light and won't stop blinking. I have replaced all the electroltyic capacitors on the power supply and the pwb-main board (the board beneath the power supply) and it still does the same thing. I then replaced the power supply with a known good one and it is still just flashing green.
My diagnostic code is also showing 12 which (according to the service manual) means "No Error Found".
Anyone have any thoughts on what to do next?
Chad
