<strong>question:</strong>
1: What is .Mod and .Tod video?
2: How to convert .Mod and .Tod video to AVI, MPG, WMV, MPEG?
<strong>Answer:</strong>
1 .MOD and .TOD is the video format generated by most popular digital camcorders such as Panasonic SV AV100, Canon MOD Camcorders, JVC (MOD and TOD) and
Panasonic (MOD only). It is not the common format, so it can not be accepted by popular portable players.
2. Now with the professional Tipard<strong> <a href="http://www.topsevenreviews.com/tipard-mod-converter.html">Mod Converter</a></strong> and Tipard <a
href="http://www.topsevenreviews.com/tipard-mod-converter-for-mac.html"><strong>Mod Converter for Mac</strong></a>, you can easily convert your Mod/Tod
video to any video format supported by your portable device.
<strong>The following will show you how to convert .Mod and .Tod video</strong>
<strong>For Windows users:</strong>
<strong>Step 0:</strong> Download and install <strong><a href="http://www.topsevenreviews.com/download/tipard/mod-converter.exe">Tipard Mod
<img src="http://www.topsevenreviews.com/guide/mod-converter/interface-n.jpg"/>
<strong>Step 1:</strong> Click "Add File" button to add your video files.
Or you can click "File" button to open the following drop-down menu, then select "Add File"to import video file.
<strong>Step 2:</strong> Select the output video format you want from the "Profile" drop-down list.
You can click the "Settings" button to set parameters of your output video such as Frame Rate, Bitrate to get the best video quality as you want.
<strong>Step 3:</strong>Click "Start" button to start your conversion.
The conversion speed is very fast, just in a short while you conversion will be finished.
<img src="http://www.topsevenreviews.com/guide/mod-converter/addfile-n.jpg"/>
<strong>More editing functions</strong>
<strong>1. Video Cutter</strong>
If you just want convert a clip of your video, then you can use the "Trim" icon to set the Start time and End time of the clip or you can directly drag the
slide bar to the accurate position.
<img src="http://www.topsevenreviews.com/guide/mod-converter/trim-n.jpg"/>
<strong>2. Video Crop</strong>
By using the "Crop" function you can crop the black edge of your video and you can also drag the line around the video image to adjust your video to portable
devices..
<img src="http://www.topsevenreviews.com/guide/mod-converter/crop-n.jpg"/>
<strong>3. Video Joiner</strong>
If you just want converter a clip of your video, then you can use the "Trim" icon to set the Start time and End time of the clip or you can directly drag the
<strong>4. Snapshot</strong>
If you like the current image of the video you can use the "Snapshot" option. Just click the "Snapshot" button the image will be saved and then click the
"Open" button next to "Snapshot" button to open your picture.
<strong>For Mac users</strong>
<strong>Maker preparation:</strong> Download and install Tipard Mod Converter for Mac (<a href="http://www.topsevenreviews.com/download/tipard/mod-converter
-intel.dmg">Intel Version</a> or <a href="http://www.topsevenreviews.com/download/tipard/mod-converter-ppc.dmg">Power PC Version</a>)
<img src="http://www.topsevenreviews.com/guide/mod-converter/addfile-mac.jpg"/>
Step 1: Load your Mod/Tod files by clicking "Add File" button
Step 2: Select the format you want to convert from "Profile". If you like to set your own data, please click "Settings" button.
Set up the output profile and the output file path. You can default the output file path or select your own path by clicking "Browse" button on the line of
Destination.
Step 3: Start conversion.
After you set all the settings, you can click "Start" to start conversion.
<strong>Tips:</strong>
The edit functions such as "Effect, Trim, Crop, Snapshot, Merge, Watermark" are also available.
<img src="http://www.topsevenreviews.com/guide/mod-converter/editvideo-mac.jpg"/>
Ok, with the powerful and easy-to-use program, convert and enjoy your .Mod and .Tod Video is so easy, have a try now!
<a href="http://www.macsoftreviews.com/iskysoft-video-converter-mac.html">Mac Video Converter</a>
<a href="http://www.macsoftreviews.com/aiseesoft-iphone-ringtone-maker.html">iPhone Ringtone Maker</a>
<a href="http://www.topsevenreviews.com/">Best DVD Ripper</a>
