1639 posts / 0 new
kellysue
kellysue's picture
Hi, i have the blinking timer
Hi, i have the blinking timer light issue. My model is a WS 48515. willyou please send me instructions on how to fix to dunnrvrkids@ca.rr.com.
thank you so much
cpriepke
cpriepke's picture
Hello, Larry,
Hello, Larry,
Well, I finally got tired of playing with this stupid issue and went and bought a new flat panel. Do u know anyone who wants a 5 yr old ws65813 with a problem with the 9 volt regulator board that controls video? If not ,it will be broken down for scrap....
Thanks for all the help and too bad I could not get a new board, vice having to buy a new flat panel.
Larry Dillon's picture
ah man this is an easy repair
ah man this is an easy repair!! if your anywhere near Michigan??
Larry D.
cpriepke
cpriepke's picture
Nope Larry, I live in Georgia
Nope Larry, I live in Georgia. Yeah, I only got info for replacing the 9 volt regulator. That has now morphed into alot more due to pads lifting and all. So if u know anyone who will want a good tv, let me know. I live in Atlanta, ga.
that means you used too much
that means you used too much heat, did you use a small wattage soldering iron??!!
Larry D.
if the pads lifted off the
if the pads lifted off the board you used too much heat, did you use a low wattage soldering iron like what is mentioned in the instructions??????
Larry D.
Wendy1234
Wendy1234's picture
HI
HI
I have a Mits 52327, I have a code 34. But i'm unable to confirm what that means. Please help
Saxman
Saxman's picture
Can you please send out the
Can you please send out the repair instructions for the Mitsubishi WS=65869
I have the green blinking pilot light
What do the cap's cost on average ?
we got the tv from my brother for two hundred bucks, and well when we went to turn it on .....nothing but the blinking pilot light
Thanx
The best advice I can tell
The best advice I can tell you at this point is to go to tvrepairkits.com and order the blinking light kit for your model of set, click here please:
http://www.tvrepairkits.com/xcart/home.php?partner=larry the kit comes with the high temperature/ high frequency/long life 105 Celsius type capacitors (not those cheap Radio Shack caps) full easy to follow pictorial directions, AND free live on-Line tech assistance in case you run into a problem, All kits are shipped out within 24 hours in most cases, 2 to 3 day Priority mail. GOOD LUCK!!!
Larry Dillon,
hugo molina
hugo molina's picture
hey larry i have a Mitsubishi
hey larry i have a Mitsubishi ws-65515 with a green blinking light that will not stop. i pay a t.v. repair man replaced the 4 captors on the DM module and still no luck. Would you please send us the information that has helped so many others?
where did you get your
where did you get your capacitors from? did you install the high temp caps?
Larry D.
hugo molina
i dont know where he got them
i dont know where he got them. but i felt it plug to the ac and after a hour or 2 the green light turn off i was able to turn it on and i got audio too.
for a day and half. i move the tv from my garage to my room and i plug it and the green would not turn off what would it be?
most likely a jarred plug or
most likely a jarred plug or connection, chech fuses F9A05 AS WELL as F9A04for continuity
hugo molina
thank for the info!!! but
thank for the info!!! but where would i find those fuses?
preemo-dino
preemo-dino's picture
Hello Larry, I have a WD
Hello Larry, I have a WD-52825 that has the same green blinking light problem if you would please send me the directions or manual to help me with this issue I would really appreciate it. Thanks in advance for any help. My email is aandino61@yahoo.com.
DaveBKen
DaveBKen's picture
On my Mitsubishi WS-65111
On my Mitsubishi WS-65111 rear projection tv, I had the same green blinking light problem and it wouldn't power up. I ordered the kit that Larry recommended, but then 10 mins later while still surfing around, I saw a post of the same problem that was fixed by disconnecting a wire connector in the front. So I tried it and it WORKED!!! I just took the front speaker grill off and saw 2 wire bundles going up towards the screen. I disconnect the smaller of the two bundles that goes to the front TV controls. Then I plugged the TV back in, waited a min and low and behold, it works perfectly. I have to use the remote because the front buttons don't work, but who cares... I cancelled my order for a repair kit and watched a great old movie.
doing it that way and not
doing it that way and not replacing the swollen bad capacitors will ruin the DM board Unless you are posting the wrong model number?!!
Larry D.
DaveBKen
DaveBKen's picture
There were no swollen
There were no swollen capacitors or any other visual discrepancies on my TV. According to the fellow who gave me the idea, a TV technician came to his place and said it was a common anomaly with this TV and probably caused by a data overload (pushing buttons on the TV instead of remote). I could probably reattach the connector and it will still work fine, it is just that I left it unconnected as a precautionary measure since I can control it with the remote.
hugo molina
hey larry still have the same
hey larry still have the same green blinking light problem from the last email
i told you that we replace 4 capacitor and i took 1 hr for the light to stop and was able to turn on tv. i unplug it and move it to my room and again whith same green and now it would not stop.
you told me to check for fuses F9A05 AS WELL as F9A04 for continuity but as
unble to find can you tell where to find them and try checking connectoin and it seem good
do you know some one in SAN JOSE, CA how can help me i will pay!!!
THANKS HUGO
hugom1718@hotmail.com
Did you get the right caps? A
Did you get the right caps? A kit?that really makes no since that it blinks for an hour than goes off?
Larry
Larry
Did you get the right caps? A kit? that really makes no since that it blinks for an hour than goes off?Maybe a bad IC on the DM? is there a formatter board in that set, are you sure of the model number?
Larry
hugo molina
i pay this tv repair and he
i pay this tv repair and he said he replace them but when he connected the card
the light would not stop and i wouldn't turn so he felt and i felt the tv plug on so after a hour or two i when back to the garage to check on the tv i saw the light was out and i was able to turn it on for almost two day
when unplug it and move it to my room and plug to turn it on and that where light would not stop!!! now!
what board did you give him
what board did you give him to replace the caps as that model does NOT have the common general DM with the 4 bad caps on it, oh by the way the caps have to be a high temp type they should be the 105 C not the 85 C
hugo molina
i just check and it's 105 fc
i just check and it's 105 fc 25v on the capacitors
when he put the card back said it has the DM and he said he replace some other lil black box that connect to the bord
hugo molina
hey larry the bord was 7 caps
hey larry the bord was 7 caps and he only replace 4 would that be it?
and the bord said DM3 on it
Karen T
Karen T's picture
Have a mitsubishi WD 62725-
Have a mitsubishi WD 62725--with the blinking green time light. No prob before now will not power up. Could i get a copy of the repair instructions? Email is imacountrygirl52@yahoo.com.
thanks,
karen
Bob Flamisch
Bob Flamisch's picture
Hey Larry, I have the same
Hey Larry, I have the same problem as everyone else with the Blinking green light on the front of my WS-65711. I would appreciate it if you could forward me
any instructions or schematic to tackle this problem. Thanks, FlamischB@aol.com
yes you should replace all
yes you should replace all seven caps, can I please have some photos of that board and the caps on the board with the board numbers for all the caps???
I will do my best to find that service manual, but Mitsubishi does not supply the schematic or the DM board as this is not a feild serviceable according to them!!they want you to replace the entire board but it is no longer available!Larry.
Mkraft
Mkraft's picture
I know this thread is really
I know this thread is really old but i dont know where else to get the info. We have a wd62725 and i dont know where the dm board is. Any kind of diagram or directions would be great. Thanks a bunch! Mariahkraft@gmail.com
