Mitsubishi ws-65611 problems
98 posts / 0 new
Nytric
Nytric's picture
I first noticed the problem a month ago when the tv's volume went up by itself and wouldn't respond to anything from the remote for my tv or cable box remote. When I pressed the down volume on the tv control panel, the volume would go right back up. I was able to reset the tv and the problem went away. Then a couple of weeks ago, the picture would start to flash from black screen to picture, with the message "Check connections or power. The connections for RGBHv or yPrPb may be invalid. The flashes happened at random times during the day and sometimes within seconds of eachother.
I was thinking that the problem was with our cable box so I checked the connections and power cycled the box and the problem went away. Now this brings us to yesterday. The screen starts to flash again so I figured it was the cable box again, however, this time I left the tv on while I shut off the cable box. The screen still flashed but from black to blue(default screen color when there is no picture). The flashes happened multiple times within seconds of each other.
 The controls from the remote was also not working and I was only able to turn off the tv from the control panel. When I turned the tv back on the volume indicator came up on the screen and moved up on its own. Pressing any button on the control panel or the tv did nothing so I had to unplug it. I waited 10 minutes, plugged it back in, and turned on the tv from the control panel (remotes still didn't work). The volume indicator came up but instead it was at its lowest setting. The volume would slide up a few notches then go back down. Pressing the device button would result in the highlighting box to "twitch" over multiple devices. Pressing the menu button resulted in the volume going up to its highest setting and staying there, regardless of anything else pushed. I decided to leave my tv unplugged overnight to see if that would help.
This morning I plugged the tv back in and the remotes still didn't work so I thought the same problems would occur. There was no flashing, and the volume came up at its lowest setting. I turned on the cable box and a picture came up. I pressed the volume on the control panel and it worked normally. I then tried the remotes and they started to work! I started to jump up and down for joy, but it was shortlived since I decided to test it and turned off the tv. Sure enough, I wasn't able to turn on the tv from either remote. I unplugged my tv again for 10 minutes and plugged it back in. The remotes still failed. I figured that this isn't really a bad thing since I change channels with the cable box anyway.
I left the tv on for about 15 minutes without any flashing or errors I could see. I decided to try the tv remote and for some reason its working. I can even turn on the tv from the remotes. I've been reading through the forums about the blinking green lights of death and the DM caps fix. I did the error code check and it returned a 12 (normal operation). At first I thought it was the DM caps, then I thought it was the control panel. I have no idea why my tv is suddenly working again and afraid that this won't be the last time. Sorry if this post is too long, I wanted to give as much info as possible. Any insight would be appreciated. Thanks in advance, Brian
Nytric
Nytric's picture
haha big ol' wall of text.
haha big ol' wall of text. when i was composing i put in paragraphs and such but it didn't go through.
Larry Dillon's picture
You could have a problem in
You could have a problem in the DM board assembly. First thing to do is open it and see if the DM power supply capacitors are swollen or bad. This could be a very costly repair unless you know how to solder and work on printed circuit boards. If you do not, play it safe and call in a pro to assist you in this repair. Good Luck
Nytric
Nytric's picture
thx for the reply. i have
thx for the reply. i have soldering experience so i'm willing to give it a shot. my email address is oddjob633@yahoo.com
I sent you the info so you
I sent you the info so you can try to fix your TV set. Good Luck
fastwillie
fastwillie's picture
I have the same problem with
I have the same problem with the DM board. Please send instructions on the repair. Thanks.
 Maybe I can willie, but your
 Maybe I can willie, but your not so fast willie? Where too?!??????????????????????????????? Sorry my crystal ball is not working today.
fastwillie
Larry Dillon said:  Maybe I
Larry Dillon said:  Maybe I can willie, but your not so fast willie? Where too?!??????????????????????????????? Sorry my crystal ball is not working today.
Sorry about that. My TV is actually a Mitsubishi WS-73615. I know one of the capacitors is bad because it burst, probably from a voltage surge. the email address is wdtnattatum@yahoo.com. Thanks for the help.
Are you sure of the model
Are you sure of the model number?  And how old is this TV set?
fastwillie
The model number is off the
The model number is off the rear of the tv set & off the Owner's Guide brochure (dated 2004). It is about 3 years old. It is a rear projection 73" 1080i set & its comparable 65" model is WS-65515 & WS-65615.
fastwillie
I did not receive the
I did not receive the instructions for the capacitor replacement. Please send to wdtnattatum@yahoo.com. My model number is WS73615. Thanks.
I do not have that model
I do not have that model number of TV set but you can go to servicemanual.net and get one. Then you can help me out as I am helping you out by sending me a copy of the service manual. I will though however send the different capacitor replacement documents.
b-mac
b-mac's picture
I have a similar problem with
I have a similar problem with my WS 65611.  4 years old, and this is first problem.  The TV shut off by itself and the green light blinked.  We were able to turn the TV back on and we didn't notice anything different until a few days later.  The convergence was way out of whack.  Tickers on the bottom of the screen rolled down off the left and right.  I tried the Advanced Adjustment for convergence, and the white lines were bowed at the bottom.  So we couldn't get the red or blue to match the white lines, but I'm not sure you would want to.  I hit the reset button, and now the TV will not power up at all.  Nothing, no blinking lights.  I've unplugged, etc., and nothing.  I pressed and held the Menu and Device buttons on the front panel.  Nothing.  No blinking lights, nothing.  Is this likely the DM board I've read so much about?  Or a fuse?  Can you take out the DM board without taking out the chasis?  Any advice would be helpful.  I'm pretty handy, and if I can pinpoint the problem, I will order whatever capacitors that I need and take the DM board somewhere for soldering.
b-mac
b-mac's picture
Larry Dillon said: I do not
Larry Dillon said: I do not have that model number of TV set but you can go to servicemanual.net and get one. Then you can help me out as I am helping you out by sending me a copy of the service manual. I will though however send the different capacitor replacement documents.
Larry, I have the service manual in PDF format for the WS 65611 if you want it.  I need help fixing the TV.  Power shut off by itself, then convergence was out of whack.  I hit reset button and now TV will not come on at all.  I've read about the DM board problems.  Any advice?  I'm pretty handy, but i'm not sure i want to solder anything.
Please send the PDF to
Please send the PDF to techman32k@yahoo.com
frank sr.
frank sr.'s picture
I have a Mitsubishi HDTV 1080
I have a Mitsubishi HDTV 1080 Model WS-65515 and have the dreaded flashing green light of death. I was hoping to follow the capacitor replacement advice to the DM module. After downloading the service manual, which quite clearly showed the location of the DM module...it is clear that our t.v. does not appear to have the DM module as illustrated from the manual on the  web.  We purchased the 4 capacitors as suggested but are unclear which ones to replace if any at all seeing as our t.v. appears not to have the DM module.  Any advise would be greatly appreciated.
I downloaded the manual from http://www.eserviceinfo.com. It's a fantastic site but on this occasion the manual appears to be the wrong one and I cannot find the right one.
Anyone out there have any ideas?
Jim, your model number does
Jim, your model number does have a DM board but it is not the same one for the four capacitors. There are actually seven capacitors in your set that have to be replaced all at once. I have the right service manual as well as a repair documents with pictures to show you how to take it apart if you like. Leave an e-mail address and I will send it all out to you. Good Luck
frank sr.
frank sr.'s picture
Larry, That's fantastic news,
Larry, That's fantastic news, I thought I was going crazy!! My email address is jimloves2travel@yahoo.co.uk  It would be a great help you could include what value of capacitors I need to replace. I'm trying desperately to repair my girlfriends TV before flying back home to England tomorrow. Thanks Larry, I really appreciate your help.
On their way to you Jim. Good
On their way to you Jim. Good Luck with the repair.
jmcmath
jmcmath's picture
I'm having the same problems
I'm having the same problems with the flashing green light. I would appreciate help with diagnosis and fixes for my ws-65611. Thanks. jmcmathortho@hotmail.com
The repair instructions are
The repair instructions are on their way. Good Luck
looney
looney's picture
I have a Mitsubishi HDTV 1080 Model WS-65611 and have the dreaded flashing green light. Could you send me info on how to repair DM Board hallicom@hotmail.com Thanks
osman
osman's picture
I own a ws-65611 HDTV.
I own a ws-65611 HDTV. Currently I am experiencing auto power off problem. After I apply power, the green light will come on and then turn off immediately. I reboot the TV with no sucess. TV would come on with flashing green light for a minute or so, then turn off. I am handy, has access to soldering iorns and some parts. I would appreciate any suggestion including repair manual sent to me at showkat_osman@hotmail.com.
OK first thing we need to do
OK first thing we need to do is a diagnostics on the set and find out why it is shutting off. Press and hold down the input and the menu button on the tv set, the standby LED wil blink a two digit code like 5 times. Let me know what it does. Good Luck
osman
osman's picture
Larry, where is the standby
Larry, where is the standby LED on WS65611. Are there one or multiple LED. Do I have to open the back of the TV?
it is the light that flashes
it is the light that flashes when you reboot the set. There is only one, and nNo you do noy have to take off the back of the set.
osman
osman's picture
Larry, I pressed "Menu" and
Larry, I pressed "Menu" and "Device" button simulteneously which are located infront of the TV. It appear to go into a self test mode. The green light will go on and off (slowly) and then go on, off, on off in repid succession then the first on and off. Then the cycle repeats 5 times. Seems like the codes are in binary, 1 0 ( or 1 1 0 0) and 1 0 1 0 which are 2( or 12) and 10 in decimal. If I had not read it correctly, please let me know, I can try again. The failure mode of my TV is, when I press the power button, the green light will come on for half a second, then turn off.
I would appreciate any comment.
If the code is a 12, the set
If the code is a 12, the set does not detect a fault, I'm afraid you will need an experenced tech to trouble shoot this set.
osman
osman's picture
I am not sure if it is 12 or
I am not sure if it is 12 or 2. If the light blinks on and off slowly once, is this a 1 and a 0. After a slow on and off, it blinks on and off twice repidly. then it repeats the cycle begining with a slow on and off, followed by quick on and off twice.
Is there a serviced manual for ws-65611 that will tell me how to read the code correctly?
that is a 12 code, there is
that is a 12 code, there is no 2 code and like I aid before that the set is not detecting g a problem, if you can use a multimeter, Go in and find some small fuses that are marked right beside them on the board as F9A)4 and F9A05, if one or more of these are bad, you will need to replace the convergence IC's. If you have no experience with solid state repair play it safe and have an authorized repair person assist you in this repair.
osman
osman's picture
Larry, appreciate your help.
Larry, appreciate your help. I have a multimeter and I can replace IC's if I know which one to replace. Would you have access to board layouts and schematics for WS-65611. There are four or five boards layed horizontally next to each other. It would be helpful if I knew where those fuses F9A04 and F9A05 are appriximately located. You can send me any drawing at showkat_osman@hotmail.com.
Lord Crystallion
Lord Crystallion's picture
Larry, My WS-65611 has a
Larry, My WS-65611 has a green haze or fog to it. I've tried adjusting the Red & Blue color but nothing works. This is only if I use the HDTV setup. I assume I have a bad board. Do you have the schematics that will show me which board I need to replace. Any help you can provide is greatly appreciated.Dakota5883@yahoo.com
KevinS
KevinS's picture
I have a WS-65611 and would
I have a WS-65611 and would like a copy of a service manual, my convergence is bad, both top and bottom of display is bent inward. My email is searsk@cox.net I would really appreciate any help. I do have some technical skills would work on this myself if not too complicated.
kyleraid
kyleraid's picture
My ws-65611 has a bad dm module from what the tech people tell me over the phone. is this somehting that i can fix myself or is there somewhere i can buy a new or repaired dm module that i might be able to replace myself? Thanks for any info. my email is kyleraid@yahoo.com
looney
looney's picture
Larry Dillon said: It is on
Larry Dillon said: It is on it's way to you. Good luck
Hi Larry, Looney here I have not received any info yet on the mitsu 65611 flashing green light
could you resend that info again please Thanks hallicom@hotmail.com
kyleraid
kyleraid's picture
i replaced my capacitors but
i replaced my capacitors but the green light does not stop flashing. Do you need to put the back of the tv back on or will it work without it?
jhruzek
jhruzek's picture
I have a Mitsubishi WS55511 with the same problem as started this thread. My set randomly shuts off with the message about power ac line failed or connections for RGBHv or yPrPb may be invalid. Could you email your manuals/instructions to jhruzek@chco-cpas.com? Any other thoughts would be greatly appreciated.
jhruzek
jhruzek's picture
My set is now fixed. My tech
My set is now fixed. My tech replaced the connector at location "KE" and everything is now working as it should.
Greg4773
Greg4773's picture
The same thing happened to my
The same thing happened to my TV regarding the volume control with a mind of its own.  I cant get it off my screen.  Read that it could be a bad capacitor on the DM board.  Could someone please forward me the repair instructions?  Thanks.
dragonhue2
dragonhue2's picture
larry i have noticed that you
larry i have noticed that you havent reply tosome of the posts,are you still around.i am having a different problem with my ws 65611 .i have no power to get a flashing light.when i plug it in i hear a
dragonhue2
hi larry ,my problem is a
hi larry ,my problem is a little different.i dont have any power at all.when i plug the tv in i hear a "ping"? i dont have any light on front of tv or it doesnt turn on.any ideas,,thanks
bryce
bryce's picture
id really like the service
id really like the service manual for a mits ws65611 if i can get one. thanks
mommieofone
mommieofone's picture
The bright colors on my
The bright colors on my Mitsubishi ws-65611 have become dull and look blue, gray, and orangy/yellow. I went through all the color setting but none changes them back to normal. Does something need to be replaced or is there a way of fixing this? I have done the system reset as well. Any info would be great, thanks.
jhruzek
jhruzek's picture
I had a similar problem. I
I had a similar problem. I have my cable box feeding to my Mits WS55111 using the 3 RCA connections for Yp, Yb, etc. I found that one of the wires had pulled loose.
ITGUY
ITGUY's picture
I have a WS-65611 that will
I have a WS-65611 that will not turn on. Everything was working fine until we sent back the Dish Network Cable box (unplugged while everything was off). My son tried to turn it on to play a DVD and said that it just turned itself off after a few seconds.
So, I am thinking a power supply problem? No Light's go on and I did not see if the green light blinked before it went off.
I am a veteran IT guy and my kid's would appreciate any advice that you can provide to me so that I can fix it.
Thank You,
osman
osman's picture
I have a similar problem as
I have a similar problem as ITGUY, every time I reboot my WS65611, the green light in the front would flash for several seconds and turn off. I was told to check 2 fuses F9A04 and F9A05 which I could not find. As I opened the back, I saw 3 boards with names marked on each board; 1) A signal board with IC's and surface mounts parts to the left, 2) A DM board with voltage regulators and capacitors/inductorsin the center and 3) a main board with high voltage circuitry to the right. last year I hade a different failure mode, picture would diverge to show a shadow. When I called a local TV repairman he replaced the DM board for $700. Any idea how I can fix green flashing light problem?
Rod Crutchfield
Rod Crutchfield's picture
Hi Larry~
Hi Larry~
I own a Mitsubishi 65' rear projection HD TV model WS65611.
I am experiencing a problem with the remote and front control panel not changing the input on the TV.
The on/off button also is not responding to the remote and I must push the front panel on/off button numerous times for it to respond.
The remote is operational as it works other things. I have tried resetting the TV with the reset button and unplugging the TV for a few hours.
I have blown the front panel controls with air to dislodge any possible debris.
Can you please advise me as to what the problem might be and as to how I can repair it myself?
Also can you please forward the PDF service manual to me?
Thank you,
Jeff
mtense
mtense's picture
Hey Larry, I have a WS-65611
Hey Larry, I have a WS-65611 from Dec 2002 with the blinking green. Hoping capacitor replacement will fix it. I would really appreciate your instructions. Please email to mtense@gmail.com. Happy Holidays, Aaron
TimH
TimH's picture
Hi,
Hi,
I have a WS-65511 from about June of 03, and it started today where it would turn on, but the power light would stay on for only a second or two, then shut off.
The blink code appears to be 2 2.
Is this a DM module issue, and if so, can you send the cap replacement doc to tim at honl dot net ?
Thanks very much for your help!
TeeGee
TeeGee's picture
Larry, we experienced a power
Larry, we experienced a power surge/outage a few days ago, and ever since then I have been experiencing the dreaded "blinking green light" on my Mitsubishi WS-65611. I have checked the front switches (by pulling the harness cable) and that is not the source of the problem. I will check the capacitors on the DM tomorrow when I get off work, and I think that I'm likely to find the tell-tale bulges. I would appreciate it if you could send me the repair guide for the capacitor fix when you get a chance.
My e-mail address is jcinman2@verizon.net.
Ohio Scott
Ohio Scott's picture
Green Lights of hell.
Dude split a power poll by the home and we lost power. When power was restored green lights were flshing on ws-65611 and it would not turn on. Tried reseting and nothing. Tried unpluging and nothing.
I have read about this dm board and replacing caps. Please send all info regarding this and how to fix it manual. I would greatly appreciate it.
send to firebaseball@yahoo.com
Newsletters
Subscribe and get the latest updates, news, and more...
