Mitsubishi DLP 1080p 65". My tv also has the blinking green light described above, however, my tv seems to be working just fine. It has been blinking now for several days, but it turns on and off with no issue. Could this blinking light mean something different or a sign that the capacitor issue is imminent.
I have a 2002 Mitsubishi ws-65819. been working fine till yesterday it started with rolling pic and unwatchable distortion. then shut off and now will not turn on. will your cap repair work for my unit also? I am thinking that maybe I have ultible problems. after all it was working fine and rolling distortion started while watching IT AFTER A HOUR BEENING ON this is a extra tv that sits for months on end with no use
Hi Larry, I've got a WS-65513 with this blinking green light problem and it would not stop blinking until I unplug the power cord. When I plug the power cord again, it is still blinking green. Can I get a copy of this manual too? Please email it to [email protected]. Thanks! Larry G.
I had this problem fixed about 3 years ago by a pro while the tv was under warranty. Could you please email me the instructions for the WS65513 as well? [email protected]
F
Larry... I have also encountered this dreaded blinking light with no power-up. Would you be willing to email the valuable documents to [email protected], please? Thank you, sir!
Same exact problem, a friend gave me the tv as a"gift", and now I know why he gave it away. Could you please send instructions to [email protected]. Thank you in advance
I realize that the requests for Mitsubishi tv help are a little old but I have a Mitsubishi MS65711 with a similar problem. If you still have a copy of the procedure for fixing this rascal I would really appreciate seeing it. Inasmuch as I used to know my way around tvs, I'd also appreciate a copy of the schematic for this part of the power supply. Thanks a bunch, Larry.
Just today I had replaced the compasitors on my ws-65713.
The compasitors were clearly bad (the caps were bulged)
I replaced them with the ariganal 1000uf 16v caps.
Everything seems to be properly put back together.
I still have that damn green flashing light!
I took the board back out to make sure it was properly connected.
I actually connected it up the second time without the metal shield
is there any concerns for doing that?
We bought a tv with the same issue my husband said it was probally an easy fix Can you please send me the instructions and the Part Numbers along with the manual Thank you .
Same problem :( green blinking light of death.... model 65732 - can I get a copy of the instructions also? my kids are driving me crazy now that its getting cold out. Thank you in advance Larry!
Hi my name is Manny. Could you please email me instructions on how to fix my WS65513 with blinking green lights. Could not get to turn on TV at all even after reset. Thanks.
My friend has this Mit 65313. It seems she has the same problem. Could you send me the instructions and I can solder the caps on for her. Thank you in advance. [email protected]
Larry is it possible just to replacethe dm board itself. And if not can you send me picture of the capacitors that have to be replaced. Please. I have the tv apart. Thanks in advance.
I have a WS-65903 that just started the blinking green power light deal. Could you also send me those directions? The CRT guns are still in good shape and it would be a shame to trash the TV... [email protected]
Tim
Larry, I see you've been doing this for eight years...hope you're still going strong. I've been told by a Mit certified repairman that it's probably parts on my convergence board and would cost ~ $300-350 to repair. $10 sounds much better, will you please send me the info needed also for a WS-48511. When I registered for this site it said I would receive replies automatically now (I gather so people don't have to post them publicly anymore), but if you do need my email let me know. Thanks.
Can somone send me the instructions... trying to fix the set today before Football starts this afternoon...
TV - WD-73640
Thanks in advance for the help...
Where are these 4 capacitors located on the DM board? What are the numbers for this capacitor? and where can I get these capacitors? I have Mitsubishi WS65513. My problem is the picture looks distorted and wavy and after a while the TV shuts off by itself. Please email me the repair instruction guide/manual to "[email protected]" Thanks in advance. Rich
I have a ws-55905. I just started getting an intermittent problem. The video will disappear, while the audio continues. The screen goes black for less than 5 minutes and then comes back on and then runs fine for hours. Could this also be related to the capacitors? Is it a power supply issue or a lamp issue? Any thoughts would be appreciated. Also please send the service manual to [email protected]
Thank you!
Thanks, Matt
Same problem. Can you email me the fix?
F
So sorry for not providing important information in my previous post, Larry. My TV is a WD-62531. My email is mightymangler @ G mail . com
Thanks again!
Mine did the same thing :( could you please send the instructions to [email protected] my kiddos and I would be greatly thankful for your help.
Larry, could you please e-mail the info with the fix on this BLINKING!!! light. Thanks, Ed Saxton
Sorry Larry, I forgot to include my [email protected]
Could you sent me instructions and repair manual. Thanks
Can you send me the instructions to repair my Mitsubishi Medallion TV? Having he same problems that the other guys are dealing with.
Doug
Replacing the defective caps did not work for me!
Any other help ???
Any other help ???
Larry I have the same prob could you send me the link to [email protected]
Im having problems with one. I think its newish so hopefully its similar instructions?
