We had a power surge (blown transformer) which blew the varistor(metal oxide labelled MOV1) on my kenmore oven's control panel. I'l like t replace it but the varistor blew with such force it burned to a crisp.
It's yellow, 15mm in diameter, I can read in a column
M
Z
0
The CSA logo and below that a triangle. Not much to go on.
The board is made by Appliance Control Technology inc (chicago baseD) but I can't seem to find info on them.
Unfortunately Sears canada gives out no parts information. I ordered the entire board (400$) but will return it once I see the varistor I need since the rest of the board is fine.
ny help id'ing it ahead of time would assist greatly.
The oven/range is model c880_6782190
I have the same stove that had the same problem. The NTE 2V250 varistor workslike a charm. Also, be sur to check the condition of the wiring around the varistor, as it may have been damaged. I had to solder in a length of wire to bridge a burned out section on the back of the circuit board.
