1107 posts / 0 new
pinkydog
pinkydog's picture
Hi Larry, I'm yet another owner of a Mitsubishi (WS- 55813) with a blinking light.  Would you be so kind as to send me the capacitor replacement instructions as well as a parts source too please? Thank you, Thank you!!  Bill yobfd@aol.com
Hi Larry, received your docs -- thanks so much.  New question:
I vaguely remember a woman earlier in this thread that said her Mitsubishi went out after her heat went off.  I, too, remember that that's when our problems started -- it was the fisrt cold spell for Houston and our heat had not yet been turned on.  Soon after, a warm spell seemed to drive away the blinking light.  Since then, we've had another cold spell, another warm spell and the same thing happened so we decided to just leave the TV on 7/24.
Then the electricity went off and the problem came back.  This time my wife had the idea that we ought to use a hair dryer to gently warm up the TV thru the rear vents (setting the dryer on warm, not hot, and the fan on genntle) which worked!
So, the question is, is it okay to leave the TV on 24 hrs a day until we replace the caps?  We keep the TV on and turn off the cable box which results in a dark sort of dim glow (visible in the darkened room).  Thoughts?
Thanks again -- many people owe you a huge debt of gratitude including our family (with 2 small boys)!!
 Bill
Larry Dillon's picture
You will need to change those
You will need to change those capacitors right away. That is a sure fire sign of them going bad. The longer you wait, the less of a chance that replacing them will fix your problem. Do it ASAP! Good Luck
Spiritwolf
Spiritwolf's picture
I am also having the same
I am also having the same problem as everyone,green blinking light.My set is Ws-65611 could use help with locating dm board and repair.spiritwolf5089@yahoo.com
Spiritwolf, you could have
Spiritwolf, you could have bad capacitors in the DM board. This model though, there are seven capacitors that need to be replaced. I will send you the correct documents as well as the factory service manual Good Luck with the repair.
gkeasler
gkeasler's picture
GMAN915 said: MISSY GATES
GMAN915 said:
MISSY GATES said: please help if possible / we have a 73" HDTV mitshibushi and the green light is flashing on the front / we had a power surge but we have surge protectors on the tv and on the whole house from the electric company.  when the power surged / i went to the tv and no blinking green light but when i tried to turn it on....then the light started blinking.  it usually fixed itself in 3 days but this was last wednesday and it hasn't fixed itself yet.....i am so angry about this tv because they aren't cheap and no one around LITTLE ROCK ARKANSAS fixes them unless you bring it to them.....DUH HOW MUCH DO THEY WEIGH????  i can't believe we are stuck with a tv like this and can't even watch it.  if anyone out there has this problem / please email me with what to do crazyhorse74@msn.com i really appreciate whatever anyone can suggest....outside of tossing it out the door Yell
Vickster
Vickster's picture
Vickster said: Larry Dillon
Vickster said:
Larry Dillon said: This problem could be a bad DM board.  If you are handy or knows anyone who is, and they can solder, I have an instructional file that will show you how to take out the DM board, find the bad parts, and even give you a source where to get the parts. There are even pictures included!  Now once you get this apart, and the capacitors look good, check the capacitors, or have them checked.  I have seen in a few cases where some folks have only replaced the capacitors that looked bad.  If this does not fix your problem, you will need to have a pro come out and check out your TV set..  If you do not have a clue what you are doing, please play it safe and call in a tech.  If this board is indeed bad, the repair should not eceed 1000 bucks.  If you want this file, leave an e-mail address and i will forwar it to you.  Remember, there is a possibility that there is another problem with your TV set, but this has fixed over 65% of the peoples TV sets that I have shared this file with.  Good Luck, and let us know if this helps you.
Hi Larry, We have just had this dreaded blinking light occur to us with out WS65869.  Can you email me the file for the DM board capacitor replacement steps?  Much appreciated!  vicksternv@yahoo.com
We did the code test holding down the device butto along with the menu button and we are getting a code 22 - Short Protect.... would our problem be the fuses?  We would still like to have you send the info for the DM repair in case it is not the fuses.... Thank you for your time!
Vicki & Gary
Vickster
Vickster's picture
Vickster said: Vickster
Hi Larry, We did the code test holding down the device butto along with the menu button and we are getting a code 22 - Short Protect.... would our problem be the fuses?  We would still like to have you send the info for the DM repair in case it is not the fuses.... Thank you for your time! Vicki & Gary
Ok sorry for the 3rd posting here... my husband wanted to relay that our problem is that the TV won't turn on.  When the power it turned on it blinks for 60 seconds or so and then shuts itself off.  I found the error code test through the interenet freelists.org.  We do have the TV on a surge but the power did flicker when the TV was off.  When we turned the TV on it worked but then shut itself off.  Any assistance would be greatly appreciated.  Thank you Larry!
Vicki
bill cardie
bill cardie's picture
I have the same probem with
I have the same probem with the green blinking light.
I have the mit 52525 dlp tv 3 years old.  The service contract has just run out .(lucky me)
I have someone that can solder .
Would love it if you could send me the steps I need to take . Bill@diamondspurbuiulders.com
Thanks Bill Cardie
stlouisman
stlouisman's picture
Hi Larry- I also have the
Hi Larry- I also have the WS65613. My kids hooked a Nintendo WII to it last night and left it plugged into it all night. This morning I came down to watch the game-and now all I get is the green blinking light. I went thru the reset procedure, unplugged for a couple of hours-no luck. Can you send me the same info on how to pull the board and repair. I would really appreciate it. Thanks!
stlouisman
Larry- I didn't leave an
Larry- I didn't leave an email address for inst on how to repair the WS 65613 with the blinking timer light.  benp100@charter.net Thanks again.
stlouisman, man you get
stlouisman, man you get around. I counted like seven or so threads you posted on. One is enough. The info is coming out to you. I do not stay on these threads 24 seven. I get to them as I get to them. I will send you the info.
ikeof3
ikeof3's picture
Larry, I to have the blinking
Larry, I to have the blinking green light.  It's the Mitsubishi 1080 Integrated.  WS-55513 any help would be appreciated.  Did not notice a power surge.  Ran fine last night and tried to tunr it on about 1pm today and just got the flashing light.  Tried the soft reset and then unplugged it for about 3 hours but still the blinking green light.  thanks, my e-mail is ikeof3@yahoo.com or bruce@meiklegroup.com
Bill, I am sending you the
Bill, I am sending you the info and documents you were asking for. Good Luck with this repair.
gkeasler, what is the model
gkeasler, what is the model number of the fix your looking for?
pilot1107
pilot1107's picture
Larry:  When you get a chance, will you please send me the file for the WS65613.  Thank you in advance for your help with this matter.  Mike, pilot1107@yahoo.com
Bill Cardie, your bad e-mail
Bill Cardie, your bad e-mail adress cost me an hours worth of redoing the other e-mails because you do not know your e-mail address. Get it straight man beforte asking for help. I do have other things to do you know besides figuring out wrong e-mail addresses.
rotokid
rotokid's picture
Hello,
Hello,
I also have this same problem with my WS65613. Could you possibly send that information along to me as well? Email: rotokid@gmail.com
Obviously Mitsubishi has to be aware of this rather large problem. Do you know if this has been resolved in newer releases of the televisions? If not it seems to be their attempt to make a "disposeable" product that gets you through the warranty period. After that anything more you get is a bonus. Either way this is the last product I will knowingly  buy from the company.
Thank you so much for the information that you provide about products and problems.
rotokid, I know this really
rotokid, I know this really is a wide spread problem that Mitsubishi is totally ignoring. I will of course add you to the growing list of recipients for the repair documents that I will send out later tonight as soon as I sort through all of my e-mails. Good Luck with the repair.
CTSV04
CTSV04's picture
I have model # WD-62725 with a blinking timer light. If I unplug the T.V. for a few minutes then plug it back in and press the reset button the T.V will work for several hours. Unfortunately the T.V. eventually shuts off and again I have the blinking timer light. Any help recommending part replacement, manuals where to buy is appreciated. Please send docs to randall_schoultz@yahoo.com.
Thanks for the help,
Randy
Randy, I will send out the
Randy, I will send out the information you seek in just a little bit. Good Luck with the repair.
paulroy
paulroy's picture
Larry
Larry
I have a Mitsubishi wd-52725 with the blinking green light. Can i get the docs to remove the DM board and replace the capacitors from you? Any help would be greatly appreciated.
I would be more then happy to
I would be more then happy to send them to you, but to WHERE!! LOL
paulroy
paulroy's picture
Larry
Larry
 Thanks for the reply. I am a rookie to these forums. Please send the info to pbiedle@qwest.net.
Dan Larsen
Dan Larsen's picture
Hi, I have a ws-65869 with
Hi, I have a ws-65869 with the flashing green power light.  Can you send me this information on how to repair at larsend2@yahoo.com?
Kenny_G
Kenny_G's picture
Well, I too have the flashing
Well, I too have the flashing green light would you mind sending me some information on how to repair this problem with the DM board?
Kenny_G
kgodwin2@cox.net
vardar
vardar's picture
hello there,
hello there,
my mitsu model#is WD-65732
last nite it wouldn't turn on. I am soooo upset it has just been a year.
i did all the unplugging stuff, didnot work, i hit the power button, green light comes on, sound comes out of speakers (hssssssh) and 1-2 min later tv shuts down itself.
thats all the details,
Please help
Thank you
Buddy
vardars@bellsouth.net
mhoysa
mhoysa's picture
Hi Larry,  I have a mitsubshi
Hi Larry,  I have a mitsubshi HD1080/VS50805 with the blinking green problem.  I went to turn it on and the green light flashes a few times and the TV remains off.  I unplugged the TV for more then 8 hours hoping it would reset, but the same problem continues.  Is this the end of my TV, or can you please send me the document on how I may be able to fix it. Thanks!
mhoysa
mhoysa's picture
Hi larry... forgot to send
Hi larry... forgot to send you the email address.  it is mhoysa@marcusmillichap.com .  Please send me any information that might fix my TV.
Ken, I am getting to it. You
Ken, I am getting to it. You know it is a Sunday and I had a Christmas thing to do. I do not sit here all day waiting to answer peeps. Sorry it took longer then you expected. You have the documents shortly. Dan, look at the model number man. This is for a different model number.   Paul, what model are you asking for?
paulroy
paulroy's picture
Paul is looking for WD 52725
Thanks again Larry
Topic locked
