1107 posts / 0 new
cheshire13
cheshire13's picture
I have a WS-55813 Mitsubishi Diamond.  Thank you for sending out this info to people.  I must have sold close to 500 of Mits' tvs and earned this one for free, to only be saddened that I woke up to a blinking green light and no way to resolve the issue as in the past by unplugging or hitting the reset.  I would be very grateful if you could pass the info on to me.  My email address is cheshire132002@yahoo.com.  Once again, thank you for your time.
-LEB
Larry Dillon's picture
on its way LEB, good luck
on its way LEB, good luck with this repair.
WR_Rob
WR_Rob's picture
Hey Larry,
Hey Larry,
I have a Mits WS-73713 with the blinking green light issue... ARGH.  Can you please send me the info I need to get my TV up and running?
Thanks a lot for your help,
robertlee@earthlink.net
Leov
Leov's picture
I also have the green light
I also have the green light of death, and I have the WS-48513. Could you please send me this file as well.  Thanks!!
My email is Leoville505@yahoo.com
robertlee and Leov, the
robertlee and Leov, the information and documents you requested will be out to you very shortly. Good Luck with the repair.
starnz
starnz's picture
Hey Larry -  I've written
Hey Larry -  I've written before and you've been so kind as to send me the information on the DM board capacitor fix.  My Mitsubishi model is the HDTV 55909.  I opened it up yesterday and found that the capacitors (7 of them) are on a separate small power supply board that feeds the DM board.  It's in the shield box along with the DM board.  The capacitors looked fine... no swelling at the tops and no evidence of leakage.  I'm stumped now.  Could these capacitors be the problem on this model?  Please let me know, and send any additional information that might help with this model.  I'll order three more capacitors and do the fix if you think it has a chance!!!
 Many thanks Larry.  VERY glad you're there.
 Van
It certainly could be the
It certainly could be the capacitor, even if they look ok.
nic_nic
nic_nic's picture
I have the same problem with my model WS 55513. Can you please send me the information in easy to understand steps? Please send the info to nandrade@stx.rr.com
Nick
richardm
richardm's picture
Hello, I'm having the same
Hello, I'm having the same issue, We have a WS-65513, my email address is rmathis@h2ohq.com
richardm and nick, the
richardm and nick, the documents and the service manual is on it's way out to you. Good Luck
bluefish211
bluefish211's picture
i am having the same problem
i am having the same problem as well with my WS-55613, can i have the service manual and documents please?  thanks =D my email is bluefish21190@gmail.com
They are on their way man.
They are on their way man. Good Luck with the repair
RickEB
RickEB's picture
Larry Dillon said: Rick, I do
Larry Dillon said: Rick, I do not have that service manual but one is available HERE for you to download. Good Luck with your TV set. When you find out what was done to the set, please post back with us.
Well the tech just came out. The person that took my call thought the lamp was bad and sent the tech out with a new one. The tech said its a communications issue, and that he has to order a new board. He didnt specify which board, his quote " not the caps issue, he has seen that before on earlier models, and has never seen this happen on this model ". Any how he ordered the board and will be back in a few days. I'll keep you posted.
Rick
snickers
snickers's picture
Thank you for the "green blinking light" repair info for our WS-65513. I got the DM board out ok and all 4 caps are bulged up a lot. Would 100uf 25v caps be a good replacement?
Thanks for your help...
No snickers, those will not
No snickers, those will not work, you need 1000 mfd not 100. Try these.  http://www.mouser.com/search/refine.aspx?Ntt=140-HTRL16V1000-RC%09
dragnf16
dragnf16's picture
 I came home to the perma-blinking light problem tonight--I own a Mitsubishi WS-65613.  Is there any way you can send me the repair documents as well?  Also, I'm somewhat of an electronics novice--is the 25V or 35V capacitor going to make a difference safety-wise as opposed to the original 16V capacitors Mitsubishi used?
 Thanks in advance,
dragnf16@yahoo.com
I will send the info to you.
I will send the info to you. I use the High temp 105c 16 volt capacitors. I will have a link where you can buy them from without waiting. And they are cheap too! Good Luck with the repair.
daveoman
daveoman's picture
Hi Larry, I also have a Mitsu
Hi Larry, I also have a Mitsu WS-55513 with the flashing green light.  Tried power down for a while and back up to no avail.  I've got a soldering iron at the ready!   Thanks!
daveoman@aol.com
Raptor 1
Raptor 1's picture
Hi, Same problem here too
Hi, Same problem here too with my WS-55859 little green power light keeps flashing and will not go off.  Could you please send file to me also with the instructional file that will show me how to take out the DM board and find the bad parts,.  Thanks!! please send to librooks@snet.net
daveoman
daveoman's picture
daveoman said: Hi Larry, I
daveoman said: Hi Larry, I also have a Mitsu WS-55513 with the flashing green light.  Tried power down for a while and back up to no avail.  I've got a soldering iron at the ready!   Thanks! daveoman@aol.com
Just an update for everyone...I got it fixed.  Pulled that DM module out of there, changed the 4 1000uF 16V caps to 1000uF 35V caps, put it back together and it worked like a champ!
Thanks all.
Great news Dave. it is a
Great news Dave. it is a great feeling to save a ton of cash, especially right be fore Christmas! Happy Holidays
raptor1, I have sent out the
raptor1, I have sent out the repair documents you requested Good Luck with the repair.
LVGsm
LVGsm's picture
Larry, I am another person in
Larry, I am another person in dire need of your help
My model is a WS- 65613 and email is lvdaddiox2@yahoo.com
Thanks in advance
If your in dire need why are
If your in dire need why are you asking on a thread for a different model number? I will still send you the info as well as the service manual so you can attempt the repair of your TV set. Good luck.
AusRAP
AusRAP's picture
Larry, I apparently have the
Larry, I apparently have the same issue.  Mitsubishi ws65513 with the blinking green light.  Would you be able to send me the file to fix it also.  Thanks  Will   will.c.mckee@gmail.com
Yes Will, I will be happy to
Yes Will, I will be happy to send you the repair documents. Good Luck with the repair.
snickers
snickers's picture
Thank you soooo much! We got the caps from mouser as you suggested and took the board to a local tv repair shop to solder for us. He only charged 20.00! I'd like to send you a check to thank you for saving our tv and no doubt a high repair bill - I don't do PayPal so if you would like to send me your address I'll get it out in the mail for you. wildaboutjesus@hotmail.com
Snickers :0)
Well that is very kind of you
Well that is very kind of you my friend. I am glad the fix worked for you and saved you a lot of bread. Thats the old time term for money? LOL
Shira
Shira's picture
I am new to this site -
I am new to this site - THANKS FOR HAVING IT!!!
We have the same problem of the devil-flashing-green light from hell!!! We prefer to not pay $1000 to have some guy come fix it. We have the original manual the tv came with, but how can I get this manual with the pictures to help me do this myself??? I do not know what a DM board or capacitors are... but I am willing to give it a try.
Vickster
Vickster's picture
Larry Dillon said: This
Larry Dillon said: This problem could be a bad DM board.  If you are handy or knows anyone who is, and they can solder, I have an instructional file that will show you how to take out the DM board, find the bad parts, and even give you a source where to get the parts. There are even pictures included!  Now once you get this apart, and the capacitors look good, check the capacitors, or have them checked.  I have seen in a few cases where some folks have only replaced the capacitors that looked bad.  If this does not fix your problem, you will need to have a pro come out and check out your TV set..  If you do not have a clue what you are doing, please play it safe and call in a tech.  If this board is indeed bad, the repair should not eceed 1000 bucks.  If you want this file, leave an e-mail address and i will forwar it to you.  Remember, there is a possibility that there is another problem with your TV set, but this has fixed over 65% of the peoples TV sets that I have shared this file with.  Good Luck, and let us know if this helps you.
We have just had this dreaded blinking light occur to us with out WS65869.  Can you email me the file for the DM board capacitor replacement steps?  Much appreciated!  vicksternv@yahoo.com
Topic locked
