1107 posts / 0 new
what
what's picture
Larry Dillon said: This
Larry Dillon said: This problem could be a bad DM board.  If you are handy or knows anyone who is, and they can solder, I have an instructional file that will show you how to take out the DM board, find the bad parts, and even give you a source where to get the parts. There are even pictures included!  Now once you get this apart, and the capacitors look good, check the capacitors, or have them checked.  I have seen in a few cases where some folks have only replaced the capacitors that looked bad.  If this does not fix your problem, you will need to have a pro come out and check out your TV set..  If you do not have a clue what you are doing, please play it safe and call in a tech.  If this board is indeed bad, the repair should not eceed 1000 bucks.  If you want this file, leave an e-mail address and i will forwar it to you.  Remember, there is a possibility that there is another problem with your TV set, but this has fixed over 65% of the peoples TV sets that I have shared this file with.  Good Luck, and let us know if this helps you.
Hello Dillon:
 I have the blinking light of death, could you send me the documents to replace the capacitors.
schrodinger1@yahoo.com
hal
hal's picture
I am yet another blinking light victim. The tech that came out diagnosed a bad DM board. He ordered a new board. The tech told me it could be weeks, months or the preverbial cold day in hell before I get another board. Mitsubishi simply said they were on back order. A shipment was due 10/31/07 but couldn't tell me how many back orders they could fill.
I did a search and found this site. You guys are good. Even the tech, an authorized Mitsubishi shop, had never heard of a possible repair.
I have a WS- 65813 and would appreciate any help. ron.morton@fctg.com
Thank you, Ron
Larry Dillon's picture
I have sent the info to both
I have sent the info to both of you, Ron and schrodinger1. Good Luck
pinkydog
pinkydog's picture
Hi Larry, I'm yet another
Hi Larry, I'm yet another owner of a Mitsubishi (WS- 55813) with a blinking light.  Would you be so kind as to send me the capacitor replacement instructions as well as a parts source too please?
Thank you, Thank you!!
 Bill
yobfd@aol.com
Bill, you should have the
Bill, you should have the documents as well as the info you will need to repair your TV set. Good Luck
dho711
dho711's picture
I also have a WS-55613 with
I also have a WS-55613 with this green light flashing problem. I have tried everything i can do as far as resetting and unplugging the power for a day..  It actually worked one time for a few hrs.. then when i shut it off.. and turned it back on later in the day..  i got the green light again..  Can you please send me the info to my email  tanman69@hotmail.com to do the repair?  Thank you soo much! :)
I have sent the documents you
I have sent the documents you requested. Good Luck
vinny19
vinny19's picture
Hi Larry
Hi Larry
I also have a WS-55613 with the same blinking green light issue. My TV behaved pretty much similar to tpriddy1979's TV from above. After the first time I got this problem, TV did work for about 10 days, stopped again for couple of days, worked again for a week or so. Finally about 5 days ago I started getting the blinking green light, and the TV is is not turning on again. In fact I left the TV like that for about 36 hours with blinking green light, but still it is not working. Can you please send me the info to my email srisri@yahoo.com to do the repair? I appreciate your help
ScubaSteve
ScubaSteve's picture
Larry Dillon said: I have
Larry Dillon said: I have sent the info to both of you, Ron and schrodinger1. Good Luck
Larry
Unfortunatly it seems I am another victim to this problem. My Tv has also shut off for no reason several times over the years and I too thought it was just a power surge. This time it will not stop blinking no matter what I do. Can you please help. Here is my email address - kccarlton65@yahoo.com
Thank you
kc and srisri, I have sent
kc and srisri, I have sent the documents that may help you repair your TV set. Good Luck
jamiller1952
jamiller1952's picture
Larry, I feel terrible asking
Larry, I feel terrible asking but could you also send me the docs to address the green light problem for my WS 55813. I fear you spend your whole day sending this info to fellow members. It would be greatly appreciated. Thank you very much.
Jay
jayschap@comcast.net
JamesM
JamesM's picture
Hello All,  who has the files
Hello All,  who has the files for the blinking green light from hell?  Larry, are you still the man?  I have the ws-65869 or 909 whichever one had the hd turner built in.  Thanks in advance to whoever has these to send.  send to bsewall@cox.net
Illwills
Illwills's picture
Larry, I too have the
Larry, I too have the blinking light of death, can you help me out?
WS-55613
 This tv has been down for a couple of months now, I been contemplating a repair. Your a life saver!!!!
jelkins28@hotmail.com
R2B2
R2B2's picture
I have that same blinking
I have that same blinking problem that I cant get rid of it A Mitsu 65 inch Diamond W65813. Could you send me the same files you did the others thanks. mklinkefus@tampabay.rr.com. Thansk a million
dd99
dd99's picture
Hey there, I'm having the
Hey there, I'm having the same problem with my television and I'm wondering if you can send me the instruction manual on how to replace the broken parts.  Thanks.  My email is ryangutierrez@cox.net
Ryan
juniornike
juniornike's picture
Larry -
Larry -
Is repair for the blinking green light problem the same for the WS-48511, I have 7 capactors instead of 4 on the DM Board.If so can you send me the repair files.
thanks for your time
take care
rcrawf3@tx.rr.com
The directions for both types
The directions for both types are on their way to anyone who left a good e-mail address. Good Luck.
R2B2
R2B2's picture
My blinking light deal is
My blinking light deal is like this. When I turn on the TV in the morning the light flashes for how ever long unknown more than 10 minutes right now. But when I come back at the end of the day the TV is off I turn on the TV it comes on no issues. Its like something is holding it from comming on at a specific time. Any ideas.
zapdbf
zapdbf's picture
klinker, i am not an expert
klinker, i am not an expert on this repair, but i do know the behavior of capacitors. and if they are malfunctioning, they can change their behavior un predictably due to temp.
I agree what zapdpf said,
I agree what zapdpf said, these capacitors in this set will most of the time have different symptoms, and yours is for sure one of them. Go in if your able and change the caps before they blow out the surface mounted fuse(s), or cause other damage to the DM printed circuit board.
Robert T
Robert T's picture
My WS-65711 started experiencing this problem today. If you could be so kind as to please email me the instructions to fix the problem, I would be grateful.
 TIA,
Adam
ws65711@fordhaminc.com
Kachnina
Kachnina's picture
Larry,     Seems to be a good fix for many. Can you send me the file??  It would be much appreciated.  My TV (WD-52725) takes a dump seems like only during football and hockey.  Your file may keep me from putting my foot through the Green Blinkin' thing.  Thanks,  streakerdt@comcast.net
The documents will be in your
The documents will be in your hand very soon. Good Luck to you all.
silverbob
silverbob's picture
Larry Dillon said: The
Larry Dillon said: The documents will be in your hand very soon. Good Luck to you all.
I have a WS-65813 mitsubishi 65" screen as well....could you plz send me files to repair  4 capacitors. THX so very much.
*Did Mitsubishi get bought out by Tiawan?...rofl
No, but they use China
No, but they use China capacitors. Must be too much lead in the paint?  LOL I am sending you the files you should need to complete the repair including the factory service manual so you can not only see how this beast comes a part but also, aft6er you do repair your TV set and save a butt load of cash, You can see how the front screen comes off and you can clean the mirrors and lens. If you would have left an e-mail address. Sorry, my crystal ball is broken. Where would you like it sent? Good Luck.
silverbob
silverbob's picture
Larry Dillon said: No, but
Larry Dillon said: No, but they use China capacitors. Must be too much lead in the paint?  LOL I am sending you the files you should need to complete the repair including the factory service manual so you can not only see how this beast comes a part but also, aft6er you do repair your TV set and save a butt load of cash, You can see how the front screen comes off and you can clean the mirrors and lens. If you would have left an e-mail address. Sorry, my crystal ball is broken. Where would you like it sent? Good Luck.
oops, must have been eating lead paint chips.....Lpickap@msn.com.....thx
jonny
jonny's picture
I too have the blinking green
I too have the blinking green light on my ws-55813  can you send me the information as well, Thank you.  jethrid@yahoo.com
Robert T
Robert T's picture
For some reason the documents did not make it to me.  Can you send them to me again, please? My email address is ws65711@fordhaminc.com.
I am sending out another
I am sending out another mailing of these repair documents soon, this after noon. Good Luck with the repair.
wormy
wormy's picture
I am having the "blinking
I am having the "blinking green light of death" also with my WD-52725. If you could send me repair documents, it would be greatly appreciated.
Thank You
Topic locked
