1105 posts / 0 new
fussled
fussled's picture
Hi Larry, I am have the same
Hi Larry, I am have the same problem with the green blinking power light on my Mitsubishi projection TV Model WS-55813.  The light is blinking, reset does nothing and the TV doesn't come on.  I have read some of the other post and I am new to this site.  Could you e-mail me the instructions on how to fix this problem.  Thanks in advance.   My e-mail address is Rawlsbuck@aol.com.
pj
pj's picture
Larry Dillon said: Val and km
Larry Dillon said: Val and km, I have sent you the documents you requested so you can attempt the repair on your TV set. If you do not know how to solder, play it safe and find a friend or a pro to unsolder and to solder these capacitors, as the PC board is very small and can be easily damaged. Also remember that this is not a place to be experimenting around inside of so if you do not know what something does, don't mess with it. Be careful. Good Luck
Hi Larry:  I've got the same problem - 55813 Mitsubishi TV and green blinking light that won't go away.  Can you send me the stuff?
pj
pj's picture
SMR said: Hi Larry, I am have
SMR said: Hi Larry, I am have the same problem with the green blinking power light on my Mitsubishi projection TV Model WS-55813.  The light is blinking, reset does nothing and the TV doesn't come on.  I have read some of the other post and I am new to this site.  Could you e-mail me the instructions on how to fix this problem.  Thanks in advance.   My e-mail address is Rawlsbuck@aol.com.
Larry:  Sorry...forgot my email.  It is bradweech@cox.net
mjbaker65
mjbaker65's picture
I also have a WS-55813 that had a powering on problem with the green blinking light. I received the instructions from Larry and was able to fix it.  I hadn't really had much soldering experience, but it was very easy.  From start to finish took me a couple of hours as I worked slow to make sure I understood and did it right. I'm confident I could do it in half the time.  Thanks so much Larry!
Larry Dillon's picture
Your welcome mjbaker65. It is
Your welcome mjbaker65. It is really nice to put that 800 to 1000 bucks in your pocket instead of a repair persons pocket. Nice job!
eesmdt
eesmdt's picture
About a week ago the power went on and off during the night. My t.v. was not on but when I walked into the living room the green light on the front of the T.V. was flashing and I tried turning the television on with no luck. I unplugged it and plugged it back in with no luck. I then left it unplugged while I went to work and when I came home and plugged it in again, the green light started flashing again and no power. The television was plugged into a serge protector that came with the television but still it didn't help. Could you please e-mail me the instructions so maybe I can try to fix this problem on my own?
Thank you very much in advance,
Jalin
Sorry I forgot to put the email address. I guess that would help.
jalin@cableone.net
Thanks again.
fussled
fussled's picture
It's me again, SMR.  Please send me the instructions (Rawlsbuck@aol.com) for fixing the power blinking light problem.  Thanks a bunch!
fussled
fussled's picture
SMR, I am still waiting for a
SMR, I am still waiting for a model number. There are two different DM boards in these TV sets.
eesmdt
eesmdt's picture
I forgot to put an email address contact on my post. Could you please send instructions for a
ws-65869 to jalin@cableone.net.
JaLin
jaLin, I sent the documents
jaLin, I sent the documents you requested. Good Luck
fussled
fussled's picture
Larry Dillon said: SMR, I am
Larry Dillon said: SMR, I am still waiting for a model number. There are two different DM boards in these TV sets.
Hi Larry,  Please accept my apology.  I put the model number in my original e-mail , but neglected to include it in my second one.  The Model # is WS-55813.  Thanks again.  Rawlsbuck@aol.com
eesmdt
eesmdt's picture
Larry Dillon said: jaLin, I
Larry Dillon said: jaLin, I sent the documents you requested. Good Luck
Thank you very much I received your instructions.
JaLin
SMR, I resent the documents.
SMR, I resent the documents. Hope they get to you this time. Good Luck
Steven Jones (not verified)
Guest's picture
'Looks like you da man, Larry
'Looks like you da man, Larry!  My WS65869 bit the dust yesterday, so I'm now requesting the "fix" tutorial, please! (I'm good with tools, having built my own Heathkit TV long ago!)
One additional question in my case, tho:
- I had the blinking light problem once a year or so ago, but it went away on power cycle so I thought nothing of it. This time I did NOT and do NOT get a continuously-blinking light, rather the power light comes on for 2 secs and then goes off.
No power-down/power cycling will get it out of this mode now, either. :(
This began during a mid-viewing shutdown by the TV: Wife was watching football yesterday (I'm a "football widower!" My wife MAKES ME WATCH FOOTBALL WITH HER! Woot!) and the screen went black. Ever since then it's been stuck in "green light on for only 2 secs" with nothing but a black screen. (I.e. Its not on long enough for the CRT to warm/fire up, I don't think. FYI: It DOES do the normal boot-up blinking which DOES stop after the usual duration. Attempts to power-on thereafter get the 2-secs attempt before going off again.)
I'm wondering if the CRT went out?
Anyway, strangely enough I purchased an extended warranty with the thing when I bought it in 2002 and guess what? It's up in 4 weeks!  ... It's still on warranty... and they're coming out to "fix it(?)" Tuesday! That NEVER happens, does it?!?
I've downloaded the service manual for the TV and would like to have your info in-hand as well when the repair guy shows up Tuesday, so when he pops the back of the set off I'll know what to look for to see if this is my problem!
TYiA, and thx for helping all these ppl on this board!
Homer(55)
Guest (not verified)
Guest's picture
Homer55 said: 'Looks like
Homer55 said: 'Looks like you da man, Larry!  My WS65869 bit the dust yesterday, so I'm now requesting the "fix" tutorial, please! (I'm good with tools, having built my own Heathkit TV long ago!) One additional question in my case, tho: - I had the blinking light problem once a year or so ago, but it went away on power cycle so I thought nothing of it. This time I did NOT and do NOT get a continuously-blinking light, rather the power light comes on for 2 secs and then goes off. No power-down/power cycling will get it out of this mode now, either. :( This began during a mid-viewing shutdown by the TV: Wife was watching football yesterday (I'm a "football widower!" My wife MAKES ME WATCH FOOTBALL WITH HER! Woot!) and the screen went black. Ever since then it's been stuck in "green light on for only 2 secs" with nothing but a black screen. (I.e. Its not on long enough for the CRT to warm/fire up, I don't think. FYI: It DOES do the normal boot-up blinking which DOES stop after the usual duration. Attempts to power-on thereafter get the 2-secs attempt before going off again.)  I'm wondering if the CRT went out? Anyway, strangely enough I purchased an extended warranty with the thing when I bought it in 2002 and guess what? It's up in 4 weeks!  ... It's still on warranty... and they're coming out to "fix it(?)" Tuesday! That NEVER happens, does it?!? I've downloaded the service manual for the TV and would like to have your info in-hand as well when the repair guy shows up Tuesday, so when he pops the back of the set off I'll know what to look for to see if this is my problem! TYiA, and thx for helping all these ppl on this board! Homer(55)
This is the same exact thing that happened to my ws-65869 and on the same DAY!!! Only my warrenty is up. Any one know what I can do to fix this? Maybe the same thing with the DM board? Send any info to mdirrigation@gmail.com thanks
guerita
guerita's picture
My Mitsubishi WD62725 is also doing the blinking green light.  Would really appreciate some guidance.
wesb33@sbcglobal.net
Fit4u2
Fit4u2's picture
I have the same problem on
I have the same problem on the ws-55613... Is there anyway I could get those documents?
wickedss
wickedss AT gmail DOT com
Julie Strietelmeier
Julie Strietelmeier's picture
Firemab68 said: Larry
Firemab68 said:
Larry Dillon said: This problem could be a bad DM board.  If you are handy or knows anyone who is, and they can solder, I have an instructional file that will show you how to take out the DM board, find the bad parts, and even give you a source where to get the parts. There are even pictures included!  Now once you get this apart, and the capacitors look good, check the capacitors, or have them checked.  I have seen in a few cases where some folks have only replaced the capacitors that looked bad.  If this does not fix your problem, you will need to have a pro come out and check out your TV set..  If you do not have a clue what you are doing, please play it safe and call in a tech.  If this board is indeed bad, the repair should not eceed 1000 bucks.  If you want this file, leave an e-mail address and i will forwar it to you.  Remember, there is a possibility that there is another problem with your TV set, but this has fixed over 65% of the peoples TV sets that I have shared this file with.  Good Luck, and let us know if this helps you.
That would be great!!!  You can send it to bekajo830@aol.com Thanks!
I could also use this file. Same problem! Please email to: bnitcartledge@yahoo.com
I have sent you all above the
I have sent you all above the manual and documents you requested. Good Luck But I wish if the model number is not listed at the beginning of the thread, you really should start a new thread with the right model numbers to make sure you receiver the proper materials to work on your TV set.
Digg@lot
Digg@lot's picture
Hey Larry Just currious on
Hey Larry Just currious on this problem... Still undergoing my others...but
Any Clue on a  45 inch rear projection mitsubishi that leaked coolant on to the signal board & now the darn thing won't even come on. Any clue on this Project?
Sorry, Diggs. depends really
Sorry, Diggs. depends really on what was damaged on the printed circuit board. It is impossible to tell without checking it out. The board that was leaked on can be sent to ptscorp for repair, as long it is not to badly corroided. Look up the number from the website I gave you and call them to see. Good Luck
quickn
quickn's picture
Larry would you mail me the
Larry would you mail me the instructions as well? WS-55613 .Thanks
VAbeyta@Aol.com
tray
tray's picture
Hello. I have been having the
Hello. I have been having the same problem with my ws-55513. I had a power outage during the night and the set has not turned on since. Before then whenever i would turn the set off it would take longer and longer for the blinking timer would stop. Could this be something else or what?  LARRY DILLON....could you please send me the repair manual!! I cannot afford to have it repaired so i am going to have to try it alone. Also, please tell me where i will be able to get the parts as well and about how much they should cost. Would be greatly appreciated. Email to Sophialicious@yahoo.com
vin and Sopha, I have sent
vin and Sopha, I have sent you the repair documents and the factory service manual. Good Luck
tray
tray's picture
Larry Dillon said: vin and
Larry Dillon said: vin and Sopha, I have sent you the repair documents and the factory service manual. Good Luck
Thanks Larry, that was fast. I will let you know how i do.
Mzawsome
Mzawsome's picture
Hi Larry.  I have the same
Hi Larry.  I have the same green blinking light issue with my Mitsubishi big screen.  It is about 3 years old and it is a model 65713.  I left on a trip and while I was gone my wife told me that the TV would not turn on and that the timer light just kept blinking green.  I have since reset the TV unplugged it over night and tried to get it back to running, but the only thing it does is blink that green light.  Can you please send me the fix instructions.  My email is cmustama@yahoo.com.
Cameron
lambrc
lambrc's picture
Larry,  I have the fast blinking light problem after I had the box powered off and unplugged for 5 days.  I have the service manual for the WS65869 but the files you mention above would be helpfull to check the capacitors or to order any parts I may need. Thank you in advance for sending me the files.
How about a copy of the
How about a copy of the service manual to techman32k@yahoo.com and I will forward you the documents I have. You did not leave an e-mail address, where would I send them to?
dalenanda
dalenanda's picture
Hello Larry
Hello Larry
       I have the green light of death on my WS 55513 . Well at least I hope its as easy as replaceing a few caps. Green light blinks nonstop after power went out and the tv wont turn back on. It has done this before and most of the time I could get it working again with a flash disc I got from Mitsubishi. but this time it wont work. please send me the info on how to replace the caps on my tv. erickyletaylor@yahoo.com thank you in advance :)
