Mitsubishi vs-60707
20 posts / 0 new
budman
Mitsubishi vs-60707
I just recieved the set from a friend for a great price. Problems are there is a red,green line 1 inch from top when started and the picture flickers here and there. Both problems stop over time guess warmed up. I know about electronics and can replace caps etc..
thanks
Chris
Can you post a picture or
Can you post a picture or send it to [email protected]?  That would help me to see about where the problem lies.
cupojoe
http://img356.imageshack.us
http://img356.imageshack.us/img356/6849/dsc00196wx1.jpg
http://img405.imageshack.us/img405/903/dsc00197kp9.jpg
 http://img398.imageshack.us/img398/930/dsc00198sz8.jpg
Sorry about the crappy pics they ame out a little dark. The first pic you can see the wavy picture towards the bottom. I describe it like the tracking on a VCR
Chris
bgreen292000
I also have a vs-60607 with
I also have a vs-60607 with picture when i have in the split screen mode there is a blue line at the bottome of the screen. then in normal operation there looks like to have what looks to be a tracking problems on a vcr.. any sugestions on what the problem could be and how to fix it would be greatly appreicated
cupojoe
Guess Ill bring this topic
Guess Ill bring this topic back from the dead. The set was fine all summer then as soon as the cold settled it started again. I got these things to check from another site where should I start. I removed the board from the set already.
thanks
chris
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB
You would have to make some checks:1. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. You can try and change that cap first. Hope this helps
These sets have a PIP module which is plugged into main board and has a brown ground wire to the can.Surface mount caps c7001 and c7036 are usually the problem but if the capacitors have leaked too much you may never recover the board,CURE eliminate PIP by putting 10 mfd 50v cap from pin 5 to 11 and another from pin 9 to 7 on the VP plug under the main PCB
Jump out the PIP board first.
Jump out the PIP board first. You may be able to take out the PIP board, send it to ptscorp.com and they can overhaul it. But like I said, you need to put the capacitors across the pins of the PIP cocket first to see if this is indeed your problem. Good Luck
cupojoe
I cant seem to find the VP
I cant seem to find the VP plug what and where is that? and didnt locate the brown ground wire.
Should I start with the caps and the regulator they seem to be cheap easy to replace. Im going to run out to the electronics shop to pick some stuff up tomorrow
Thanks Again
Chris
Get the service manual first
Get the service manual first from servicemanuals.net and e me a copy. e can go from there.
cupojoe
Ok sent manual I replaced the
Ok sent manual I replaced the caps and now I have a xray circuit protection fault 21
any help
Ice
What caps have you replaced?
What caps have you replaced? Did you replace the regulator. Look at the HV regulation circuit. It gives you a block diagram in the service manual.
Kevincotton
I too have the same problem
I too have the same problem with my Fathers Mitsubishi VS 60607 , About 1 to 2 inches top and Bottom have red and blue lines, the Picture also statrs to flicker the longer the set is on, If Larry is out there can you please help me, You did wonders for my 65 in last year. Kevin Cotton , Thank you inadvance
Sorry do not have that
Sorry do not have that service manual, but if you download one from www.servicemanuals.net, and forward a copy I will see what I can do for you.
Kevincotton
I just sent it, Thank you for
I just sent it, Thank you for your help TechLore Team [[email protected]] is that correct?
Kevincotton
Address no good, Where should
Address no good, Where should i send it ?
impulse
I also have a VS-60607, that
I also have a VS-60607, that i believe is having the same issues, and then some. I occasionally have a green pwr light that will only come on for a second or two, then eventuall it works fine for awhile. (random intervals).
It also has the bars across the top and waves in and out depending on signal being inputted as well..
I've finally tore into the back of it, and there appears to be only 1 cap that is bubbling.. But i would like to replace all that are associated with it... is this the correct cap?
I also believe that the answer to my 1st question is replacing the 2 STK392-110 's..
This is somewhat a general overiew, if im not mistaken, the DM is on the right hand side? Near the power supply? or am i totally wrong here..
http://img234.imageshack.us/my.php?image=1002009kh1.jpg
the only cap i could find that was popping up was this one:
http://img374.imageshack.us/my.php?image=1002010ut3.jpg
heres a close up of the left side... which is where the converger ICs are located.
http://img360.imageshack.us/my.php?image=1002011tl2.jpg
My email address is [email protected]
Thanks!!
I Really Doubt if it is the
I Really Doubt if it is the STK IC's causing your problem? yes the cap you show Looks bad BUT to bee sure RSR the cap first also SET THIS Age-could have several bad capacitors in the main power supply or maybe the sweep power supply? ESR all the caps in both,
Debsews
My neighbors VS-60607 60"
My neighbors VS-60607 60" projection tv just started this: Turn it on and it automatically clicks and turns off. Any ideas for resetting or other fix?
Debsews
Debsews
Debsews
JoeMc
I have a VS-60707 and have a
I have a VS-60707 and have a different problem from those above. When I turn my tv on it makes a click sound and turns back off. My grandkids had the remote and since then it has not worked - is it possible they hit some sort of timer button - or should I stop blaming the kids....
Joe
always777
i have a 45 inch mistubishi
i have a 45 inch mistubishi model number vs 60707 i have somehoe gotten myself to split screen and cannot remove it to get to full screen i only have a direct tv remote that i can use on tv as well to get to menu can anyone helpme
