1999 Sony Trinitron Color TV Model #KV-35S40
19 posts / 0 new
Sue55
Sue55's picture
Last week I was watching tv late at night and the tv worked fine- the
next morning it would not turn on -we get no picture or sound and
when you turn it onthe red light keeps flashing - a repair man will
come to home for a $45.00 service charge to just look at it - and then
charge additional for any repair - have already decided not to spend a
lot on it - any suggestions-Thanks
Larry Dillon's picture
How many times does the power
How many times does the power light flash.  Take a look at This. Get back to us and let us know what you found out.  Good Luck
Sue55
Sue55's picture
Larry: The red light  stays
Larry: The red light  stays flashing - does not go off - Sue55
A Continuous blink once a
A Continuous blink once a second, no pausing means no reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.  most likely a short in the power supply and sorry to say, this is not a job for a handy person.  Please play it safe Sue55 and call in a trained servicer to repair this set for you.  Good Luck and please keep us informed.
martinez4005
martinez4005's picture
Hi I have 37 inch sony
Hi I have 37 inch sony trinitron color tv model kv-35s26 that when I turn it on the standby light blinks on and off for like 2 to 3 minutes after the 2 to 3 min go on the screen turns on. When the screen turns on it starts to blink on and off but the sound works fine. In the back of the tv is the tube and theres a little knob that you can turn when I turn it the blinking goes slower but keeps blinking and if you countinue to turn it the screen goes black and some lines that go horizontal in blue green and red appear. If you know what wrong with it can you explain it to me and also can you tell me how to fix the problem. Thank you for your help
Sounds like there is a
Sounds like there is a problem in the video 1K circuit, or the picture tube is bad.  Without you knowing how a circuit works, I cannot explain exactly how you can fix something. You will need to get and know how to use a multimeter, have a service manual and know how to read it.  Have an ESR capacitor meter and know how to use it.  This is not rocket science but it is not as easy as changing tubes like in the old days.  If you understand drive circuit, you can check the picture tube with a restorer /analizer.  You will need an ociliscope to look at the video if there is a problem there.  it is just way to muck guesswork on problems like this.  A TV set is not the place to be experimenting around inside of. Play it safe and call in a trained tech to assist you in this repair.  Good Luck, and let us know how you made out with this repair.
Richkatz
Richkatz's picture
My Sony Trinitron KV-32S40
My Sony Trinitron KV-32S40 has the following problem:
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
How do I fix it? I called 3 different TV service places and they want a minimum $150 just to come take a look. They all said Sony dosen't make parts for a TV over 5years old. Is my TV's problem fixable or is it time to replace it...UGH!?
speper
speper's picture
my sony trinitron flashes
my sony trinitron flashes from pic to blackness none stop. it takes about 2-3 min for it even come on. any suggestions
ricky1
ricky1's picture
i have horizontal green lines
i have horizontal green lines picture still fine on sony wega three years old
Sony TV, KV-35S40
Sony TV, KV-35S40's picture
My TV just turned off but the
My TV just turned off but the stand by light continues to blink, they smething wrong with the reflextion part, is it true?
And there is no static on the screen of the TV when turn on. Is it easy to fix this kind of problem?
ricky 1 sounds like a bad
ricky 1 sounds like a bad picture tube man
Sony TV I do not understand
Sony TV I do not understand your problem what is a reflextion part?
larry Dillon
nicp10
nicp10's picture
my tv is a sony trinitron
my tv is a sony trinitron color tv and for a while it wouldnt turn on but if i unpluged it for about a day it would turn on when i plugged it in but lately it wont turn on no matter what i do. i need help. FAST!!!!
Ben Sona
Ben Sona's picture
I have a 32' Sony Trinitron
I have a 32' Sony Trinitron tube from 14 years ago. These days the picture takes a long time to appear after I turn on the power and it sometimes disappears when I watch it forcing me to turn the power off and start the TV again.
Why does this happen, is it just on its way out?
Jazzbird
Jazzbird's picture
1999 Sony. Turned on this
1999 Sony. Turned on this morning - no picture - no sound 4 blinks, a longer pause, then four blinks.Any advice?
nena
nena's picture
i have a sony kv35s40 when i
i have a sony kv35s40 when i hit the poer button it the light on the bottom that says stand by timer blinks so far for 3 minutes my eyes are crossing i cant count anymore but i have no sound and no pivture please help
naayik chinaan
naayik chinaan's picture
Hi my sony tv 21 inch tv old
Hi my sony tv 21 inch tv old model no power dead I changed STR now power ok .but blinks two power light .any1 can help
bigrobtheactor
bigrobtheactor's picture
Same problem here, model KV
Same problem here, model KV-24FS120. Any help? Four red flashes, pause, repeat. No picture.
Ricardo Andrade
Ricardo Andrade's picture
Hello i have Sony triniton KV
Hello i have Sony triniton KV 32FX66E it blinks four times, i clean the board G D, D2 and A then it blinks 2 times pause 2 times, if i press power button on remote 3 times pause 3 times, i disconect the 2 cables on board C and conect again and now i have 8 blinks, pause 8 blinks pause....no imagem and no sound
