Location for repair/service manual for Sharp Microwave R-1460,1470,1850,or 1870 series
7 posts / 0 new
Jim_Fitz
Jim_Fitz's picture
After receiving a replacement door safety switch for my Sharp Model R-1461 microwave, I now find I am unable to remove the outside plastic cover of the door to install the replacement switch. No service/repair manual was supplied when purchased, and Sharp tells me that it's not a consumer repair.
KittyRN
KittyRN's picture
At the top of your microwave
At the top of your microwave is a vent with three screws...undo all three screws and gently slide this panel off. Then you will see one screw just above your control panel...remove this...then just below your panel on the underside of microwave is a screw...remove...now open your door to the microwave...you may have to work with this if your's is broken...this is how you get to the underside of control box. I had mine apart because I need a new fuse...good luck
DaveBl
DaveBl's picture
On Feb 24 you said you
On Feb 24 you said you replaced the fuse just inside the conrol panel. I need to do the same, but I don't know what size (how many amps, slow-blo or fast) the fuse is. Do you remember?
Jim_Fitz
Jim_Fitz's picture
DaveBI
DaveBI
I think your request for help should have been directed to KittyRN. I replaced a door switch only. The answer from KittyRN though seems to indicate she/he (?) needed a new fuse. I hope you get your answer .
john benitez
john benitez's picture
How do i remove the sharp r
How do i remove the sharp r-1460 from the wall.
john benitez
how do i remove the r-1460
how do i remove the r-1460 from the wall
strkalex
strkalex's picture
Well, you can refer to https:
Well, you can refer to https://www.youtube.com/watch?v=VukLE01hKpA for removing the oven from the wall.
