Emerson TV problem
10 posts / 0 new
lydjen
lydjen's picture
Emerson TV problem
My emerson tv is acting weird. My remote does not work and the buttons on the front of the tv do not properly work. The power button works fine. However, the volume and channel buttons do not work. When I press the menu button it does nothing...however, if I hold down the menu button it turns the volume up. When I let go of the menu button the volume involuntarily turns itself down to zero (no volume). To make it even more odd, when I hold the menu button down and then volume goes up I can then hold down the volume button and it will "hold" the volume at its current intensity. Then when I let go of the volume button it goes back down to zero (no volume). I'm really not sure what to do. I don't know if it is worth the investment to take it in to get it repaired. Do you have any idea what the problem is and what I might be able to do, if anything, to fix it? Please let me know.
Matt Whitlock's picture
Without knowing a little more
Without knowing a little more about the TV, it's hard to say if it's worth fixing. Given the Emerson brand, I'd be inclined to say no. You can always read "How to Determine if you Should Repair a Broken Device" for some advice on how to decide.
Guest (not verified)
Guest's picture
I agree with Matt on this one
I agree with Matt on this one...considering the make of the tv probably it's not worth fixing.
Kelsay
Kelsay's picture
I have the same problem with
I have the same problem with the same crappy TV...Ever find out how to fix?
lilygillis319
lilygillis319's picture
Have you been able to solve
Have you been able to solve this problem? My Emerson tv is doing the exact same thing.
Divina
Divina's picture
Ha, I get the menu screen
Ha, I get the menu screen popping on and off my screen for no reason, then the volume goes down to nothing and the volume bar and the menu screen alternates popping on and off. I shut the tv down and left it off overnight. I turned it on this morning and had to do that by the front of the tv as the remote wont work. I turned the volume up, by the button on front, and it went right back to zero. I still have the volume bar on the screen, and it indicates that my volume is all the way down, but so far it has not been flashing the menu screen..we shall see though.
yazzie
yazzie's picture
Remote problem: buttons 1 to
Remote problem: buttons 1 to 3, and channel change button not working. Emerson brand. Manual change works.
yazzie
yazzie's picture
phillystyle
phillystyle's picture
WOW! You are describing
WOW! You are describing exactly the samething that is happening to my tv and its the same tv. I think Emerson should replace our tv's for free this sounds like a manufacture defect and they really need to replace our tv's. Emerson if you're reading this please contact me and do the right thing and replace our tv's!!!
phillystyle
I'm having the same exact
I'm having the same exact issue. Emerson replace our tv's!!!!! It's the right thing to do!!!
