I have a 52 inch RCA HDTV and my two year old grandson shut the power switch off on my power surge cord. When I turned it back on the TV wouldn't show a picture. I have sound but no picture. Could somebody please help me before I blow this TV up. lol
I am new at this so please excuse my ignorance. I have a 52 inch RCA HDTV and I have it plugged into a surge protector. My two year old grandson switched the surge protector off and shut down my television. When I switched it back on my television won't show a picture now. I have sound but no picture. My son took the back off and he said it is not the bulb. Could you please offer me some advice on what to do.
i have a 36inch flat screen 2006 tv i went to turn it on the red light came on but no picther or sound and when you push the power button again the light will not go out you have to unplug it
i have 2006 36 inch rca tv when you push the power button the red light comes on but no picther or sound and when you push the button again the light will not go out you have to unplug it
I have a 52 inch RCA HDTV and my two year old grandson switched the switch on my powersurge cord and now we can't get a picture. We have sound but no picture. We have no manualfor this television. Could somebody help me before I blow this tv up...lol
i have a rca 52 inch tv. and i have three different colors showing on my tv red,blue,green i can watch tv but the pic is a double pic how can i correct the problem.
I take it that it is a projection tv if so i would replace the two conversion chips on it ( 2 big chips attached two heat sinks) if u know what your doing not to diff. if u dont i recommend calling someone who does
You should a switch PCB where the buttons are. You can either buy a new switch PCB or change out (solder) some new switches to this switch PCB. I changed out the switches and it ran me $5.00 and a little patients.............
Hi this id DougTech. This is a simple problem that is very simple to fix. First your going to want to have a universal RCA control. Then take off the batteries and press the number 1 for 25 seconds, Then put the batteries back on and then turn the TV on and it will work normally. Wish luck
Very Simple problem to be fixed in seconds. First your going to get any kind of RCA universal control. then Your going to take out the batteries and then press number 1 for 25 seconds and then put back the batteries and then turn the TV on. Then everything will be back to normal. Good luck
I have a rca SDTV. The indicator light is red but the tv will not turn on either by remote or by front button. I have unplugged it for about 30 minutes and plugged it back in. The indicator light blinks red several times and then stays red. It is about a 38
Thanks for your time
i have a rca 52 inch tv and my tv showing three color can somebody tell me how to fix the color
RCA tv's usually don't have these convergence ic's.
what is the exact model number of tv look on back
my t.v. model 20f420t wont turn on because i accidentally put fpa lock on and i dont know how to turn on the tv.
use the remote control that should get it on, or do you also need the unlock code?
the red ,green,and blue colors are seperated.screen is blury.and picture is not square.how can i fix this problem ?
what's your make/model number, and have you lost the convergence menu in the setup menu?
What is thw model number and or chassis number?
Ok is s0o nt truu wen ppl say u need da originall control.. u wana unlock ur front panel or FDA???
holla at me ritte quikk..
all u need is a rca universal control n take off the batteries and hit number 1 for 25 seconds, after put the batteries on and boom . ha!
Take off batteries, hit the button 1 for 25 seconds than put batteries back on and it will start working normally. Good luck
Take batteries out and then hit the button 1 for 25 seconds and then put batteries back on and it will start working normally.
hello i have a RCA and one day all the tv stop detecting all the inputs to the tv, anyone have i idea on what the deal is?
