HELP
I NEED HELP IN FINDING OUT WHAT HAPPENED TO MY CAMCORDER pANASONIC MINI DV MODEL# PV-DV953
I WAS TRANSFERING A HOME MOVIE i SHOT INTO THE DV. A MESSAGE OF INCOMPATIBLE DATA APPEARED THIS HAS NEVERED HAPPENED BEFORE. DID I ACCIDENTLY CHANGE A SETTING IN THE MENU OR WHAT? THIS IS NOT COPYWRITE MATERIAL IT IS A HOME VIDEO PLEASE HELP
GAIL
Incompatible data
Tue, 05/10/2005 - 13:23
Incompatible data
You may have forgot to set the input jack to IN mode. Here's a snippet of the info necessary to complete this task from your user manual.
Copying an S-VHS or VHS Cassette to your DV Cassette
After connecting the Palmcorder and the S-Video, Video, Audio Output Jacks B of the other equipment, start the following procedures.
Note: You need the Remote Controller. [Palmcorder]
1. Set [VCR FUNCTIONS] >> [AV IN/OUT SETUP] >> [AV JACK] [IN/OUT].
2. Insert a blank Cassette with an erasure prevention tab.
[Other Equipment]
3. Insert a recorded Cassette and start playback.
[Palmcorder]
4. While pressing the [REC] Button, press the [PLAY] Button. (Both buttons are located on the Remote Controller.)
5. Press the pause button or stop button to stop recording.
[Other Equipment]
6. Press the Stop Button to stop playback.
Try this and see if it gets you going.
To Matt Whitlock
I follow everything in the manual to no avail. I talked with the Panasonic tech support and again a dead end. Is ther anything esle I could try or another way to transfer from VHS to my apple laptop using final cut pro
Sure,
Ron Repking wrote an entire article series about transferring VHS and analog tapes to digital formats like DVD. One of these articles is dedicated to transferring digital video to a computer capture card.
He has some other articles that could also give you some other ideas. Click here for some other ideas.
