Black&White NTSC playback
Wicanpe
Hi, I have a Daewoo VCR Combi GB20H1TS which says it's NTSC compatible and a multiregion DVD player Toshiba SD220. However, when I try to play some NTSC format DVDs, they play only black and white. Why is that?
sutliff2
Without knowing what type of
Without knowing what type of video you are watching it's difficult to assess the problem. With all the plasma, digital and crt televisions available NTSC may only work well on certain types. Computer monitors are definitely not an option, so that could be a reason, but assuming otherwise it very well might be the kind of television you are using.
Look up NTSC and you'll see it does have it's limitations.
