Getting quality sound performance has been a priority for all car owners. If you spend more time in your car, it makes sense to upgrade to a new system. One way to improve your driving experience is to add a subwoofer to your car audio system to get loader and cleaner sound. Adding a subwoofer can pose a problem if you don't have enough space.
One of the most known companies in the car audio business has designed special subwoofer enclosures (JL Audio Stealthbox) to solve this problem. Stealthboxes are enclosures loaded with high quality JL audio subs The Stealthbox is designed to improve the bass performance without taking so much space. Not only that, these JL Audio enclosures also blend in your vehicle's interior.
Advantages of the JL Audio Stealthbox enclosures:
1) Preformes better than other custom encloused subwoofer systems.
2) Looks like an original part of your car's interior.
3) Each enclosure is designed to fit your specific car without sacrificing space.
Disadvantages:
1) Installing this type of enclosures may require a profesional assistant to avoid problems.
2) Some JL Audio Stealthboxes are not designed to perfectly match OEM colors.
Stealthbox Design:
The secret for the un-matched performance of the JL Audio Stealthbox systems lies in the exclusive approach taken in their design. Each Loaded subwoofer enclosure is hand-crafted from fiberglass or AMC (Advanced Molded Composite) materials.
Fiberglass provides a level of enclosure rigidity and dimensional stability not offered by other materials, allowing wall thickness to be reduced compared to a typical wood enclosure. This offer car owners more interior box volume for a given external volume (which means louder, deeper bass) Fiberglass and AMC materials are extremely strong and can be molded into very complex shapes. This type of construction gives us the ability to design your Stealthbox to fit perfectly into rigid spots so as to minimize space loss and maximize performance. You won't go wrong with a Stealthbox.
What types of cars can it fit?
Stealthboxes can fit into many cars such as BMW, Buick, Cadillac, Chevrolet, Chrysler, Dodge, Ford, GMC, Honda, Hummer, infiniti, Isuzu, Jeep, Lincoln, Lotus, Mazda, Mitsubishi, Nissan, Pontiac, Porsche, Scion, Toyota and more.
