GatherNote Provides Easy Organization & Annotation of Photo-based Projects for iPad
Your projects have photos, notes, and audio.? How are you keeping it all organized???
GatherNote™ is an easy to use, all-in-one app that is ideal for organizing your projects and keeping all the relevant information in one place.
GatherNote™ is great for Architects, Engineers, Contractors, Maintenance Personnel, Real Estate Agents, Urban Planners, Interior Designers, Landscape Architects, Landscapers, Naturalists, Scientists, Insurance Claims Adjusters, Home Inventory … really it’s for anyone who makes observations and needs to know where they were and remember what they saw.
Take Photos
Quickly take photographs or use images from your photo library. Use the convenient pin pointer to indicate which direction the photograph is looking.
Take Notes
Easily take notes and pin them right at the location it needs to be. And with the pin pointer, you can show the relationship to the image below.
Draw Dimensions
Drawing dimensions is a snap using the dimension pin. The enlarged cross-hairs help you accurately place each dimension point.
Record Audio
Recording audio with GatherNote™ is as easy as a couple taps. And it’s just as easy to pause and restart when recording or playing.
Powerful Nesting
With the ability to nest pins inside of pins (images inside of images), this app is an extremely powerful tool for mapping out where you were and what you saw.
Add Tags
You can add tags with names, numbers, and prices to your pins. Choose tags from the standard tag library or create your own tags in the custom library.
Search & Filter
GatherNote™ incorporates powerful search and filter capabilities so you can keep your projects organized and get the information you need quickly. Search and filter by tag names and words in your notes.
E-mail PDF’s
Once your project is underway, you can quickly send a beautifully formatted PDF of all or just some of the things you observed via e-mail.
Available on the App Store. Only $4.99 for a limited time!
Links:
www.gathernote.com
http://itunes.com/apps/gathernote
